First Carb Sync - does this look OK?
Old May 13, 2008 | 07:15 PM
Involute's Avatar
Utardian Extraordinaire
Involute is on a distinguished road
After removing and installing the carbs a half dozen times to get the jetting in I was expecting a lot more unbalance than this. This is only the second time I've tried to sync carbs in a lot of year of riding. I spliced in and added tubes per Gregs site and I'm pretty damn sure everything was sealed well because if I removed the caps while running the idle increased. Am I kidding myself here? Is this really not that good? It seemed to make no difference if I capped off the two extra tubes on the Motion Pro unit.
At idle:
100_0717.jpg?t=1210731285
at 3500 RPM:
100_0718.jpg?t=1210731327
Old May 13, 2008 | 07:31 PM
superbling's Avatar
I can usually get it a "tad" closer at idle but I've never heard or done a 3500 reading. What's that all about?
Old May 13, 2008 | 07:40 PM
Thumper's Avatar
Personally i would try to get them closer at idle and 3500 rpm. I don't use the mercury style gauges thou.
I have a bank of four dial gauges and just connect each gauge one at a time to calibrate it off of the same carb, then i connect up to both carbs via my perminently re-directed hose connections and and turn the single screw as needed.
Old May 13, 2008 | 08:26 PM
RK1's Avatar
RK1
Assuming the numerals are inches and the liquid is mercury, it looks like you've got them within spec, but just barely. I use ATF in my homemade sync gauge and usually get the columns within a half inch of each other, but that is equivalent to like a sixteenth of an inch of mercury. At least on my VTR, getting them REALLY close makes the bike run noticeably better.
Old May 14, 2008 | 05:58 AM
Involute's Avatar
I'll do some more tweaking but won't it make one or the other worse? It's high on the right at idle and high on the left at 3500.
Yes, it's mercury.
I'd rather have them syn'd at 3000-4000 rpm because I don't normally spend most of my time at idle.
Thanks folks.
Old May 14, 2008 | 10:07 AM
RK1's Avatar
RK1
I've only ever adjusted them at idle. When I get them really close, it runs good everywhere. I never checked at higher rpm so don't know what to tell you.
Old May 14, 2008 | 10:17 AM
SlowHAWK's Avatar
Your pretty close... I found the balance between will change some as your RPM changes... so I just dial them in as close as possible on idle, and have been pretty happy.
J.
Old May 14, 2008 | 10:21 AM
If you get them dead on at idle they will be equal at 2500 rpm too... never failed yet for me...
Old May 14, 2008 | 06:38 PM
Is that a large column of water on the right tube above the mercury?
Old May 14, 2008 | 06:57 PM
Jim TT's Avatar
Jim TT
The farther you open the throttle the less cab sync comes into play because you are adjusting the slide heighth starting point which effects idle a lot. It looks OK; if a road test show good driveability your are done.
Old May 14, 2008 | 07:07 PM
Involute's Avatar
Yer a Fart Smucker
Worked out the same way for me.
Greg, it very may well be water but I'm not 100% sure as it's a borrowed manometer. You're probably going to tell me that what I've done is garbage now because of water in the unit huh?
I'll head back out there and see whats up.
Yea, it appeared to be some water. I looked at it closely off the bike and saw a line. I gently blew in to the hose and it went in to the reservoir. Now it looks like there may be a little water floating above the mercury in the reservoir.
I'll do it again after I get the wheels back on. I assume as long as the waters on top and I'm only drawing mercury the next time I'll be OK.
Good eye!
2Phaast
Feb 13, 2011 08:22 PM
Kators
Dec 13, 2009 06:13 AM
Forde
Oct 4, 2009 01:15 AM
Bill Zebub
Jul 19, 2008 08:29 PM
andy9743
Apr 8, 2008 06:35 PM
