Fairing question...
Old Jul 28, 2013 | 10:00 AM
Fistfullofthrotl718's Avatar
Fistfullofthrotl718 is on a distinguished road
Fairing question...
So I am about to embark on some fairing repairs. I am going to do all the prep work and have my local Maaco paint them. I was doing some research on repairs and discovered that some older fairings aren't made of str8 fiberglass, but a fiberglass injected plastic. From which I gathered you can not use a simple fiberglass repair kit. You would need a 2 part epoxy with "bubbles". Can you guys shed light on what material is used for the fairings? And is the about accurate? its a 98. Thanks
Old Jul 28, 2013 | 10:15 AM
Use fiberglass to fix fiberglass- like a stingray corvette or aftermarket race fairings like sharkskinz. Use a plastic welder or a plastic epoxy to fix your plastic stock fairings. There are lots of options out there but I've had fantastic results from this stuff. It's cheap, extremely strong & when used and prepped properly makes the repair stronger than the surrounding area. Buy this stuff from permatex because it's nice and thick and easy to work with. If you get a similar brand from home depot, etc it's too runny and impossible to work with.
Old Jul 28, 2013 | 10:52 AM
Stock fairings are ABS, not fiberglass.
Old Jul 28, 2013 | 05:23 PM
ok. thanks you.
Old Jul 28, 2013 | 05:55 PM
KCCO's Avatar
This thread may be helpful. https://www.superhawkforum.com/forum...r-paint-30233/ Also, Be weary for Maaco.... I have a buddy that works there that wont let them paint his car.
klwolff
Jan 5, 2010 03:24 PM
Blue Ridge Boy
Apr 20, 2009 10:39 AM
Alpar
Jan 29, 2008 09:16 PM
