Exhaust coatings/wrapping
Old Nov 27, 2006 | 05:04 PM
I found some high temps exhaust wrapping "cloth" (I had originally bought for my snowmobile) laying around and decided to wrap my headers. I started with the rear one, wanting to isolate the system and limit heat transfer into the shock. I then thought I'd wrap underneath to reduce the heating of the sump (when stopped in traffic...yikes!!). So I ended up using it all up by doing the front cylinder right to the cylinder.
I decided to try it, it didn't cost me anything.... What are your thoughts on the effect of heat wrapping? What about thermal /ceramic coatings? Help contain the heat? Any power improvement (a hotter pipe should allow gases to flow more easily) ?
Your thoughts gents (and ladies) ?
cheers
Old Nov 27, 2006 | 07:23 PM
vitter's Avatar
vitter is an unknown quantity at this point
I have heard that they can cause the metal to get brittle and crack.
Although I have never seen any evidence to support that claim.
Old Nov 27, 2006 | 07:37 PM
They are a no-no on thin walled stainless and Ti. Our stock headers are definitely NOT thin walled, and IMO are not stainless. But...according to the metallurgists 304 is actually stainless steel, though it is low grade. Exhaust wrapping should not be a problem. I would avoid getting them wet however.
Old Nov 28, 2006 | 04:04 PM
SNGPerformance's Avatar
SNGPerformance is an unknown quantity at this point
I think I'm going to have mine coated and then wrap them also.
Old Dec 1, 2006 | 11:28 PM
shayne's Avatar
I have heard when wet, they promote corrosion. A friend of mine lost a set of car pipes because of this happening.
I have Ti headers, and I didn't particularly like the look of the Ti as it didn't match my stainless mufflers, so I had them ceramic coated. Looks fantastic, and gives greater thermal efficiency as well according to all reports.
Old Dec 13, 2006 | 10:28 AM
Arctic Fire's Avatar
Arctic Fire is on a distinguished road
I'm looking into wrapping mine right now too, but i can't seem to find wrap in Canada? any suggestions anyone? what width is best to use? I am thinking of the 2".. I am going to try to find tan as well, it takes dirt a little better and has a track look. Opinions? comments?
Old Dec 13, 2006 | 10:37 AM
ebay has header wrap. I got mine from there but have yet to put it on. I'm waiting for a special day.
Old Dec 13, 2006 | 12:25 PM
I picked mine up at a place that does work on diesel truck exhausts, they had tons of it in stock. The stuff I picked up was about 3" wide
Old Dec 13, 2006 | 07:05 PM
Texassuperhawk's Avatar
Texassuperhawk
Maybe Jegs or Summit, I got mine at Competition Sales here in Houston.
Old Dec 13, 2006 | 07:07 PM
Advance Auto Parts has it in their catalogue but my local store does not keep it on the shelf. It's a two or three day item and I think they only stock 2".
Old Dec 13, 2006 | 09:04 PM
Waaaayy too expensive at Advance. I priced it here and they want like $50 for a roll and the little clamps. I got mine on ebay for about $20.
http://search.ebay.com/search/search...le=header+wrap
Old Dec 17, 2006 | 05:35 AM
thehandyman's Avatar
thehandyman is on a distinguished road
i put it on my bike last year. noticed a little diff. in the summer with the heat issue. as far as power i dont know.
Old Mar 5, 2007 | 10:23 PM
Exclamation Heat Wrapping
I got some 1" wrap years ago from Warshawsky's. I chose 1" because I thought it would conform to bends better. You are supposed to "paint" the wrap with a HT coating, which is supposed to minimize moisture absorption and provide chemical resistance for the wrap. They also recommend not using more than a 1/4" overlap to prevent hot spots and allow the header to still cool adequately. They say you get better performance and lower fuel consumption and that the mixture should be leaned out slightly because:
"By wrapping headers, exhaust gas heat within the header is maintained. This translates into better exhaust flow because the hotter the exhaust gasses stay, the faster they flow out of the engine. By improving the scavenging of spent gases, the engine breathes more efficiently. This reduces contamination of the intake fuel air charge with exhaust gases. Thus allowing the engine to develop more power with less throttle.
Why is it necessary to lean the motor down in most applications with the wrap?
Air/fuel mixture is enriched due to cooler intake and increased exhaust velocity. Increased scavenging of the exhaust has an effect on the induction side of any motor. Clearing the combustion chamber more efficiently means more efficient flow of the incoming air fuel mixture."
They also say it would take 30+ years for heat wrap to cause nominal deterioration of the header.
Old Mar 9, 2007 | 06:58 PM
Thumper's Avatar
Actually the wrap holds up very well and does not cause a problem when wet. Mine has been on for nearly 5 years. I use simple green on my wrap when i wash the bike to keep it clean. I have been caught in the rain and ridden with it soaking wet just after a wash.
The proper way to install header wrap is to saok it in a bucket of hot water and then wrap it as tight as you can pull it around the pipe. Installing it wet cause it to stretch a little and then when it drys it shrinks back to normal size and is like steel. I use two runs of safety wire at each end to hold it on. The proper end to start on is the rear so the over laps are correct.
Here is a pic of mine installed with my track day body work on the bike
Old Mar 9, 2007 | 07:13 PM
Really nice, Thumper but the final touch would be to coat the header so that it's chrome all the way back. Really like all the work that you've done to the bike.
mikstr
Jan 3, 2013 06:36 AM
budd
May 25, 2012 09:32 PM
MUHerdFan
Apr 16, 2007 03:32 PM
SlowHAWK
Feb 4, 2007 07:26 PM
RickB
Nov 14, 2005 06:11 AM
