Connecting rods measurements
Old Apr 16, 2009 | 04:26 AM
gboezio's Avatar
Not tearing in the engine yet, but has anyone here measured the Big end ID, small end ID, thickness and distance between both ends ??
I'm looking for stronger rods.
Thanks
GB
Old Apr 16, 2009 | 04:54 AM
shayne's Avatar
Can't help you I am sorry.
But why do you want stronger rods? To my knowledge, this is not a weak point in the engine. I believe you will break the crank (engines 140hp and up from memory) before having problems with the rods.
Old Apr 16, 2009 | 05:41 AM
FL02SupaHawk996's Avatar
Fastest Color
Thanks
GB
I'd beat Roger would tell you!
http://www.revolutionuk.co.uk/
Old Apr 16, 2009 | 05:49 AM
gboezio's Avatar
Going to higher RPM, the crank will destroy itself, forced induction setups tend to bend the rods, on boosted bimmers 75-80 hp per rods is the upper stock rods limit.
I'm trying to find some cheap replacements first.
Mostly for next winter project.
mikstr
Dec 19, 2010 05:36 AM
mikstr
Jun 11, 2009 08:03 AM
mikstr
Feb 27, 2009 10:54 AM
Miked9
Feb 17, 2009 01:17 PM
gboezio
Apr 10, 2007 06:36 AM
