changing sprockets
Old Jun 14, 2007 | 02:10 PM
ryan's Avatar
ryan is on a distinguished road
changing sprockets
don't want to focket up! anyone ever change sizes to modify performance? need suggestions unless stock size works best. (front and rear) thanks
Old Jun 15, 2007 | 09:22 AM
marmaladedad's Avatar
Hmm?
+2 in the rear is a fairly good upgrade for the Superhawk.
If your front sprocket and chain are worn, you'll want to replace those too.
Old Jun 15, 2007 | 09:31 AM
Besucher98's Avatar
Besucher98
Why is +2 good, what is the gain?
Old Jun 15, 2007 | 09:53 AM
VTRFan's Avatar
VTRFan is on a distinguished road
I did -1 on the front sprocket and its supposed to be a 10% increase in acceleration over stock, seems to of helped mine, seems snappier and you can tell its geared down a bit on the highway. Nothing extreme of course, but i think it did help. Good Luck!
Old Jun 15, 2007 | 10:38 AM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
No offense, but do a search and you'll find lengthy discussions and many threads on this topic with a wealth of information.
Old Jun 15, 2007 | 10:39 AM
DocPigskin17's Avatar
DocPigskin17 is on a distinguished road
-1 front/+2 rear
I have the 520 DID chain, AFAM 15 front/43 rear. Skipping all the technical bs, it is just a snappier ride and much more fun than the stock 16/41 IMHO. 1st gear does rev a bit high, but I use the SH more as a fun toy to take out and run some curves with so for me the 15/43 is a blast!!!
Old Jun 15, 2007 | 03:03 PM
ryan's Avatar
why would i be offended? i'm new, just looking for info anything i get is appreciated. looking for a little better shift pattern between 2nd and 3rd
Old Jul 2, 2007 | 03:00 PM
RacerX's Avatar
RacerX is on a distinguished road
For what is worth
I downloaded a handy little gear calculator to help with making my decision on gearing.
Now take it for what it is and that is a “Calculator” and will not factor in things like rolling or air resistance but was helpful none the less. (Note All Speeds Are At Redline)
I have three deferent Calculators and all will come up with slightly deferent #’s but it (all where within a few MPH of each other) gives you a look at how gearing changes will affect the speed of the bike in its respected gears.
Stock 16/41 – 1st 60 mph, 2nd 91, 3rd 115, 4th 136, 5th 152 & 6th 171 (if only the hawk had the HP to pull this gearing)
16/43 - 1st 57 mph, 2nd 86, 3rd 110, 4th 130, 5th 145 & 6th 163
15/43 - 1st 54 mph, 2nd 81, 3rd 103, 4th 122, 5th 136 & 6th 153
alientestsubject
May 18, 2010 03:48 PM
VoodooDog
Jun 4, 2007 06:04 PM
xecutech
May 13, 2007 12:11 PM
xecutech
Apr 2, 2007 10:00 AM
jakeeboy
Oct 31, 2006 06:24 PM
