carb sync - front cylinder fitting
Old Mar 22, 2010 | 10:51 PM
jay956's Avatar
So time for my first carb sync. Got everything i need, except the fitting the goes into the front cylinder. Where can i get one? (make one?)
Old Mar 23, 2010 | 01:50 AM
dsevans's Avatar
dsevans is on a distinguished road
It is a honda part # that a dealer will probably have to order. I can't seem to locate the # yet. I found it on this web site somewhere.
I'll try to find it later.
Darren
Old Mar 23, 2010 | 02:16 AM
RK1's Avatar
RK1
I think this is it.
http://www.onlinemcparts.com/product...214mb0000.html
16214-MB0-000
fits a pile of different Hondas so local dealer should have it.
Old Mar 23, 2010 | 09:11 AM
Yes that is the part # here is the Ron Ayers fiche:
http://fiche.ronayers.com/Index.cfm/...LINDER_HEAD_FR
it's #7
Old Mar 23, 2010 | 09:13 AM
jay956's Avatar
Awesome, thanks guys
Old Mar 23, 2010 | 09:15 AM
tbartley's Avatar
If you can get it at your local dealer, it should run only about $4. That'll save any shipping from internet orders.
Old Mar 31, 2010 | 02:06 PM
jay956's Avatar
any suggestions on how to get that bolt out of the front cylinder. i cant get it to budge.
Old Mar 31, 2010 | 02:29 PM
RK1's Avatar
RK1
What are you using? I'd try a six point socket, not a twelve point. Breaker bar would be better than a ratchet. I'd apply short, sharp raps to the handle with a hammer or mallet.
Old Mar 31, 2010 | 02:35 PM
jay956's Avatar
its a 4mm allen bolt, theres barely any room for my hands.
Old Mar 31, 2010 | 02:54 PM
RK1's Avatar
RK1
Didn't know that as my Ca. spec bike comes with the part installed already.
All I can think of is placing the allen head wrench in the bolt head and slipping a snug fitting piece of steel tubing over the shaft.
If that didn't move it I'd try an industrial grade penetrant like Kroil. Soak a cotton ball with it, squish down on the bolt, leave it for a while and try again.
Old Mar 31, 2010 | 06:11 PM
nath981's Avatar
I put a piece of tubing on mine and screwed it out, but, to my surprise, it wasn't tight.
Old Mar 31, 2010 | 06:43 PM
jay956's Avatar
the fitting that the tubing goes on isnt on the bike, its just a plug
Old Mar 31, 2010 | 07:04 PM
nath981's Avatar
well yeah. It is a little allen bolt. I forced a piece of tubing on it and it came right out. I fucked with it for quite a while before i did the tubing thing cause i couldn't get to it. A bitch of a place to get at.
If that doesn't work, cut an allen wrench end off an force it into some tubing or a small socket with the cut off allen in it.
Old Mar 31, 2010 | 07:18 PM
comedo's Avatar
Could you get a 4mm. Allen key into the bolt head using long nosed pliers or a haemostat? How about a 1/4" drive ratchet, universal joint, extension and a 4mm. Allen socket?
It's been a while since I removed the one on my VTR and I've forgotten how I did it. I do recall having to replace the brass fitting after an eager mechanic decapitated it. I needed decent access to the area to remove the remains so I took off the gas tank and air box.
Old Mar 31, 2010 | 07:54 PM
RK1's Avatar
RK1
heh. In this case "tubing" means like a piece of pipe you snug over the butt end off the allen wrench for leverage.
Old Apr 1, 2010 | 10:11 AM
dshakes's Avatar
dshakes is on a distinguished road
Can you install these and just leave them in?
Old Apr 1, 2010 | 10:30 AM
Yes, just add a piece of vacuum line with a straight fitting and plug so it's easy to get to the next time you want to sync your carbs. Then add a "T" fitting (which you also leave in and plug when you are done) to the line to the vacuum petcock and sync'ing becomes a 5min job.
Old Apr 1, 2010 | 11:09 AM
dshakes's Avatar
Very nice!
Old Apr 1, 2010 | 05:59 PM
jay956's Avatar
went out and got a allen socket that would fit it. i was able to fit it right in there, then i proceeded to strip the bolt. now i know it wasnt my tools that was the problem.
Old Apr 1, 2010 | 06:33 PM
nath981's Avatar
you mean you stripped the allen head so now you can't get it loose?
Old Apr 1, 2010 | 07:28 PM
jay956's Avatar
exactly. i'm gonna go beat up the person who did this last.
Old Apr 1, 2010 | 08:03 PM
nath981's Avatar
dam, that sucks. like someone put locktite on it and then cranked it in. Unbelievable. And mine was so loose i could have taken it out with my fingers.
You might have to use an easy out now.
Old Apr 3, 2010 | 07:21 AM
comedo's Avatar
It's such a small diameter bolt that drilling it accurately in order to use an easy out would be difficult unless you removed the head. I'd be more inclined to remove anything that might catch fire or melt from the area, heat it with a head gun and try to loosen it with pliers. I don't know if you have enough room to slot it with a dremel and use a big screwdriver or impact driver. These situations are a huge PITA. I have to be in a state of inner peace to avoid making problems like this worse.
Old Apr 3, 2010 | 08:42 AM
If you pull the carbs and the remove the isolator boot from the front cyl. you should be able to get to it with no real issues.
eyemb2
Jun 16, 2023 11:55 AM
niteridder64
Jun 8, 2012 05:31 PM
Dave Wicks
Jun 21, 2008 06:56 AM
smonska
Oct 24, 2007 10:02 AM
reaper
Sep 22, 2007 10:15 AM
