Cams?
Old 05-27-2007, 11:01 PM
RacerX's Avatar
RacerX is on a distinguished road
Cams?
I just acquired a set of stock cams and would like to have them hard welded and reground. (for performance) Anybody know who can do this?
RacerX is offline
Old 05-28-2007, 05:15 AM
ole dirty bastard
hawxter996's Avatar
webcams come to mind.
hawxter996 is offline
Old 05-28-2007, 06:10 AM
Yes, Webcams can do it, there is also another co. too, but I am drawing a blank at the moment, will get back as soon as I remember....
mikstr is offline
Old 05-28-2007, 08:44 AM
RacerX's Avatar
BTW – in the past on project bikes I have installed H.C. pistons. Is this necessary or recommended on the hawk? I have read that the lower end can only handle so much and I certainly don’t care to build a time bomb. Also what type of HP # should I expect? Thanks
RacerX is offline
Old 05-28-2007, 09:10 AM
Motohead's Avatar
Motohead
Megacycle does this also.
Motohead is offline
Old 05-28-2007, 09:16 AM
Motohead's Avatar
Motohead
That's exactly why I haven't done cams, yet (I have JE pistons). I've heard/read the crank will only handle 130, but I'm not sure how accurate that is or remember where i heard it. I would think this would vary with how you're making the additional power and your tune.
Motohead is offline
Old 05-28-2007, 10:26 AM
From what I have read from experienced tuners, you shouldn't have any problems with Stage 1 cams and hc pistons (like J.E.). It's when you start to get into Stage 2 cams and the like that you may run into problems.
mikstr is offline
Old 05-29-2007, 02:27 PM
ole dirty bastard
hawxter996's Avatar
i think roger at revolution racing said around 140 hp is max.
without bracing swingarm area.
of course without the hrc ign. module,we wont approach those figures
i believe.
Old 05-31-2007, 07:32 PM
RacerX's Avatar
Cool
Thanks !!!!!!!!!!!!
RacerX is offline
Old 05-31-2007, 07:38 PM
That sounds about right. I know a local tuner that used to build a superhawk racebike for a customer and said that it used to keep breaking cranks and was @130.
captainchaos is offline
Edwards07
08-23-2007 02:47 PM
Stumpy
06-08-2007 10:35 PM
mikstr
05-03-2007 02:24 AM
jamesvtr
04-17-2007 06:11 PM
Mick-e
02-27-2007 05:20 PM
Quick Reply: Cams?
