cam question
Old Jan 30, 2009 | 09:13 AM
Zedicus's Avatar
Zedicus is on a distinguished road
cam question
anyone ever notice that if the stock cams were swapped intake for exhaust then they would be ALMOST identical to morwaki stage 1 cams? thoughts about doing this? im gunna have mine apart soon think i should try it???
Old Jan 30, 2009 | 12:11 PM
Byrdman's Avatar
Super Byrd
hell ya you should
Old Jan 30, 2009 | 12:17 PM
FL02SupaHawk996's Avatar
Fastest Color
If you do a search I think you'll find it's been discussed, but not sure anybody did it or what their results were if they did...RC
Old Jan 30, 2009 | 12:31 PM
cliby's Avatar
its been discussed. You could also slot the cam sprockets and degree your cams to modify the timing as well which is cheap and if you are going to the trouble you can set the timing perfectly.
Old Jan 30, 2009 | 01:01 PM
drew_c14's Avatar
before and after info would be awesome!
Old Feb 2, 2009 | 09:57 AM
Zedicus's Avatar
my engine is down with a horrible rattle and running rough. so i cant get much before info. i will go ahead and try the swap but im doing the je pistons and valve job and porting while im in there so i wont be able to say exactly how big of a change swapping them alone made.
(hopefully i dont need new valves)
Old Feb 2, 2009 | 09:59 AM
Fastest Color
That rattle sound like a slapping sound?
Old Feb 2, 2009 | 11:14 AM
Zedicus's Avatar
it sounds like when the CCT's went out on all the other hondas ive ever owned. only a bit different since its a V-twin and not an I-4.
the bad thing is that when i scoped it i could hear a distinct metallic sound coming from high up in the combustion area. im really hoping it wasnt valves slapping a piston.
Old Feb 2, 2009 | 11:19 AM
Fastest Color
yep, sounds like what you're hearing is the cam chain slapping the wall of the head due to failed/failing CCT. That would also explain why it's running rough especially if the chain has jumper a tooth either on the cam sprocket or at the crank...
Is it the front jug?
Old Feb 2, 2009 | 12:00 PM
Zedicus's Avatar
actually i would sware its the rear one. but then my hearing is starting to go so im not gunna say that 100%.
Old Feb 2, 2009 | 12:07 PM
Fastest Color
could be either one, but I asked cuz most times seems the front one is usually the culprit...RC
mikstr
Sep 18, 2012 09:37 AM
mboe794
Apr 26, 2011 04:57 PM
Reb
May 2, 2008 06:49 AM
cliby
Mar 1, 2007 09:55 AM
L8RGYZ
Sep 26, 2006 07:13 AM
