cam question
cam question
anyone ever notice that if the stock cams were swapped intake for exhaust then they would be ALMOST identical to morwaki stage 1 cams? thoughts about doing this? im gunna have mine apart soon think i should try it???
If you do a search I think you'll find it's been discussed, but not sure anybody did it or what their results were if they did...RC
my engine is down with a horrible rattle and running rough. so i cant get much before info. i will go ahead and try the swap but im doing the je pistons and valve job and porting while im in there so i wont be able to say exactly how big of a change swapping them alone made.
(hopefully i dont need new valves)
it sounds like when the CCT's went out on all the other hondas ive ever owned. only a bit different since its a V-twin and not an I-4.
the bad thing is that when i scoped it i could hear a distinct metallic sound coming from high up in the combustion area. im really hoping it wasnt valves slapping a piston.
Is it the front jug?
mikstr
Sep 18, 2012 09:37 AM
