Brake Caliper Overhaul
Old Apr 23, 2007 | 12:37 PM
SnapAttack's Avatar
SnapAttack is on a distinguished road
Got my SS lines and want to clean up the calipers. Thought about replacing the seals while I'm at it and didn't know if you all suggest replacing/upgrading any thing else in the stock units. Also, what fluids are you using? Thanks.
Old Apr 23, 2007 | 12:54 PM
cliby's Avatar
pads are good to replace. I like the sintered HH pads and I think they are popular here with the stock calipers. I use DOT4 fluid.
Old Apr 23, 2007 | 06:30 PM
SlowHAWK's Avatar
I'd suggest you buy the seals at Ron Ayers.... my dealer wanted 9 dollar a seal and you'll need 8 seals for the pisotns alone!!! I think they are 3 and change at Ron Ayers... don't forget the little "O" Ring between the caliper halves as well.
J.
Old Apr 23, 2007 | 08:11 PM
If they're not leaking then there's no use replacing them. Mine are fine after 8 years and 40K. Just pull the pads, pump the lever so the caliper pistons are out about 1/2" or so (it's a good idea to use a thin piece of wood as a spacer, then remove it). Use strips of 1000 or 1500 grit sandpaper and brake cleaner to clean up any corrosion or grime built up on them, then push them back in.
The Valvoline DOT 3/4 synthetic stuff is good and is easy to find. http://www.valvoline.com/pages/produ...asp?product=51
Old Apr 23, 2007 | 08:15 PM
SnapAttack's Avatar
Thanks to all. Still got the forks on the needs list... will let you know when I'm ready Hawkrider.
Old Apr 23, 2007 | 08:53 PM
Ready when you are. No projects to work on right now. Of course that means more riding time!
mks8882
Jun 29, 2007 04:57 PM
Shmittay
May 25, 2007 05:18 PM
Random
Aug 31, 2006 01:50 AM
cb21983
Mar 5, 2006 07:32 AM
zakthor
Aug 18, 2005 10:22 AM
