Bent Fork Leg
Old Jun 8, 2005 | 06:25 PM
Mithrandir's Avatar
Mithrandir
There are a lot of options. Fork leg sliders, so long as there are no creases, can be easily straightened. If there are creases in it, they'll have to be tossed. Creases normally form right on the join of the bottom of the triple clamp, so to see it you'll need to pull them out of the bike. Make sure that when you're trying to straighten everything that you undo every bolt on the forks - including the front fender mount bolts. Sometimes the stuff down low on the forks is what holds the bends in there.
If you do need to replace them, you can normally buy just the slider from a wreckers for pretty cheap - no more than $40-$50. The sliders are also interchangable with the VFR750 and CBR600 F2 and F3 forks, so any of those will do.
Can't help you with the replacement clamps or other ideas for swapping. I'm looking into doing that myself right now as I consider heading down the streetfighter path.
Old Jun 8, 2005 | 07:32 PM
Mithrandir's Avatar
Mithrandir
Yup, that's exactly it. I'm thinking of heading down the complete custom path - sss rear, USD forks - all that will be resembling stock will be the motor and frame
If you have the forks out of the bike, then find a glass table top and just roll the sliders along it looking for light gaps to appear. You need to check all 4 sides of the tube to definitely make sure it isn't bent. It may be that the bottom triple clamp is bent, but I've not seen that before without it at least bending the fork slider itself. If the tube was bent below the seal you'd certainly know it - the suspension basically won't move and would be trapped either above or below the bend line.
As for cost and quality - the VTR forks are actually quite good - the crappy part is the springs and valving. Putting other forks in it will not make the bike any better - you'll still have to spend the same amount of money putting new springs and valves into the replacement forks. Since you'll have the stock forks out of the bike anyway, a reputable frame/suspension place should charge you no more than $100 to straighten and rebuild the basic fork. Send it to someone like Lindemanns and they'll build a good fork setup for you for about $300-400. That's far better money spent than going the USD forks, which you'd then have to spend the same amount getting setup correctly anyway. However, if you're just looking for an excuse to replace the entire front end, it doesn't matter what I say anyway - you've already got it
Old Jun 8, 2005 | 07:35 PM
superbling's Avatar
Re: Bent Fork Leg
You say the bars are "off". That could also mean the triples themselves are twisted or the bars are bent. Don't forget to check those.
Also, info gleaned from the VFR lists says that F3 forks are a tad longer than VFR forks.
Old Jun 8, 2005 | 07:50 PM
Mithrandir's Avatar
Mithrandir
If the F3 forks are a little longer, I've not noticed it before. I've never just done the slider swap - mostly I've done the fork internals swaps to get preload + rebound adjustment into the VFR forks.
Old Jun 8, 2005 | 07:58 PM
Mithrandir's Avatar
Mithrandir
Heh, missed the next set of replies.
Having a longer fork slider is only bad if you just do one - then you'd have two different length sliders and it would not look pretty. If you did both, then no difference. Loosinging the head nut by itself won't get the forks to straightened - you need to loosen everything on the forks - both upper and lower clamp bolts, the axle bolt and pinch nuts as well as the fender bolts. However, it seems that you may have already done this if I'm reading what you said above correctly (you slid the fork down to have a look for creases and to straight-edge it).
As for dropping the forks through the clamps, yes. My old VTR I had dropped 10mm at the front and raised 20mm at the rear (over the axle). There's some pics of it over in the Members' Pics area that I posted earlier today. Right now I'm VTR-less. Just sold my Mille R and looking around for it's replacement to complement my other bike - a Blackbird.
Bandit400man
Jul 25, 2013 09:02 AM
speedisgood
Jun 16, 2011 12:24 PM
john3012
May 31, 2011 06:42 PM
8541Hawk
Motorcycle News
Jul 14, 2010 01:05 PM
someonehappy
Jul 9, 2009 10:22 PM
