Any 30mm Offset Triple Clamps Bolt Right on Stock Front End?
Old Sep 25, 2015 | 08:25 PM
thedeatons's Avatar
Just like the title says...
Anyone know of a set of nice looking triple clamps with 30mm offset that bolt right onto a stock Superhawk front end (in place of the stock 35mm offset triple clamps)?
Thanks!
James
Old Sep 25, 2015 | 08:32 PM
thedeatons's Avatar
I see this has been discussed before, though never fully figured out:
https://www.superhawkforum.com/forum...-clamps-19035/
Old Sep 26, 2015 | 07:01 AM
what are the specs on the F3 front end? Mind you, I recall a thread (by Superbling?) stating that the lower triple was a weak point and flexed a lot on said bike....
Old Sep 26, 2015 | 11:43 AM
NZSpokes's Avatar
Lower triple is a common problem on Hondas. Would be good to get a run of strong alloy ones made to help the stock forks.
Old Oct 2, 2015 | 12:30 PM
A fork brace usually fixes the problem.
Old Oct 2, 2015 | 04:33 PM
thedeatons's Avatar
I was hoping for a cheap triple clamp swap from the salvage yard
James
Old Oct 8, 2015 | 09:37 AM
JamieDaugherty's Avatar
I've never heard that one before. The OEM lower clamps are fine, just heavy.
Old Oct 8, 2015 | 10:01 AM
thedeatons's Avatar
I can see where they are coming from on wanting a heavier duty clamp... Much like the sportier bikes have at least a two bolt lower clamp...
Obviously it's not mandatory, just one more way to reduce flex though.
I actually wonder whether a larger two bolt lower triple clamp would negate the need for a fork brace? Two birds with one stone...
James
jerryh
Sep 15, 2013 09:21 AM
64BitCarbide
Jun 12, 2011 09:17 AM
vtrktm
Nov 13, 2009 04:42 AM
tackybiltpro
Jan 20, 2008 08:13 PM
vtrktm
Dec 31, 2007 03:38 PM
