Any 30mm Offset Triple Clamps Bolt Right on Stock Front End?
Just like the title says...
Anyone know of a set of nice looking triple clamps with 30mm offset that bolt right onto a stock Superhawk front end (in place of the stock 35mm offset triple clamps)? Thanks! James |
I see this has been discussed before, though never fully figured out:
https://www.superhawkforum.com/forum...-clamps-19035/ |
what are the specs on the F3 front end? Mind you, I recall a thread (by Superbling?) stating that the lower triple was a weak point and flexed a lot on said bike....
Originally Posted by mikstr
(Post 390866)
Originally Posted by NZSpokes
(Post 390871)
Lower triple is a common problem on Hondas. Would be good to get a run of strong alloy ones made to help the stock forks.
I was hoping for a cheap triple clamp swap from the salvage yard :):)
James |
(Post 390871)
I can see where they are coming from on wanting a heavier duty clamp... Much like the sportier bikes have at least a two bolt lower clamp...
Obviously it's not mandatory, just one more way to reduce flex though. I actually wonder whether a larger two bolt lower triple clamp would negate the need for a fork brace? Two birds with one stone... James |
