Another RC51 Front End Conversion (Fork Swap)
Old Jul 9, 2009 | 11:31 PM
Just finished the RC51 setup on my VTR. My goal was to make it look like it came that way from the factory, hopefully I've succeeded. Before mounting the legs I had to grind down the backside of the steering stops on the lower clamp to keep them from hitting the stay mount, then I added some allen bolts to the front-side of the stops to reduce full lock. Everything else was pretty much bolt on. I reused the All ***** steering head bearings, but ordered a new lower bearing and seal for the 954 clamp. There is a little more interference with the upper radiator hose than the stock setup, but I didn't move the radiators back at all. I'd like to take the radiators down to my favorite fabricator and see if he can angle the upper outlets inward. Overall turning radius will also be decreased, but hey, it sucks on the RC51 too. I definitely like how the color of the fork legs go with the engine covers, bonus! I've tried a few different clip on options; CBR954RR Helibars - too tall, Swatt's 2.5" rise - too tall, Vortex no rise - too short. I finally settled on a nice set of stock 954Rr clip on's mounted above the triple. The downward angle isn't all that great, but the rise is primo... everything just barely clears the fairing... they"ll do for now. Front fender was also painted to match (painted the inner fairings as well since they come unpainted from Honda on the '05's). Overall I'm very pleased with the setup, the front end feels rock solid in corners now. The rear now seems a little shakey... but I should be able to fix that with a few adjustments.
Attached Thumbnails Another RC51 Front End Conversion (Fork Swap)-2009-07-30%252015_41_07.jpg   Another RC51 Front End Conversion (Fork Swap)-2009-07-30%252015_41_31.jpg   Another RC51 Front End Conversion (Fork Swap)-dsc07257.jpg   Another RC51 Front End Conversion (Fork Swap)-dsc07258.jpg   Another RC51 Front End Conversion (Fork Swap)-dsc07259.jpg
Old Jul 10, 2009 | 07:35 AM
reaper's Avatar
Indie it looks really nice. Can you post some picture of the steering stops and allen bolts?
Old Jul 10, 2009 | 08:35 AM
cliby's Avatar
best part is once you get to ride it. Nice work so far. Love that bike color.
Old Jul 10, 2009 | 10:11 AM
cal2az's Avatar
Az/Texas Rider
cal2az is on a distinguished road
Very cool inde! I will be wanting to hook up with you for a ride when youre ready to go. I want to check out your setup!
Keep us updated!
Old Jul 10, 2009 | 10:13 AM
JamieDaugherty's Avatar
Looking GOOOOOD!
Old Jul 10, 2009 | 10:24 AM
Uh-Oh... We lost another one...
to the dark side indie...
That looks good with the colors...
Old Jul 10, 2009 | 10:51 AM
FL02SupaHawk996's Avatar
Fastest Color
yep, that's the bestest mod I've done so far
SlowHAWK's Avatar
Thought I'd post my RC51 fork swap. Not too much to report as of yet, as I'm still waiting on my front rim to show up from Canada, which needs to be sent out for powder coating when it arrives. I also still need to find some suitable clip-on's, I'm thinking CBR954RR Helibars. My goal it to make it look like it came that way from the factory. I set up what parts I had today, just to make sure it was all gonna fit. I had to grind down the backside of the steering stops to keep them from hitting the stay mount, then I added some allen bolts to the front-side of the stops to reduce full lock. I also shimmed the upper triple to get the steering lock to work. It doesn't look like I'll have to move the radiators back at all, as there is only a little more interference with the upper radiators hose than the stock setup. Overall turning radius will also be decreased, but hey, it sucks on the RC51 too. I definitely like how the color of the fork legs go with the titanium, Bonus! I didn't spend too much time measuring to set it up correctly, but i will when it goes on to stay on.
Cool... nice to see another RC setup.... and your right... you don't need to move the radiators unless your completly **** retentive (in other words if you need to know what's requried to move them, let me know!!!!)
If you have any questions along the way, LMK... I'm on my second RC swap already!!! This time I have some tricky triples though.... adjustable Attack Clamps.... they look awsome.
J.
Old Jul 10, 2009 | 01:25 PM
Well keep posting your progress as I'm about a month away from doing the same swap..... just got my front wheel today and only a couple of minor bits to still find and I'm set
Old Jul 13, 2009 | 10:53 PM
Has anybody already done the swap with a SP1 forks/CBR954RR triple combination? If so, did you do the math figure out how far up the forks need to be in the triples to get it as close to the stock geometry as possible?
Old Jul 14, 2009 | 05:40 AM
I thought there was a limit of one front-end swap per bike...
Old Jul 14, 2009 | 09:03 AM
I see you used the SP2 forks, how did you make that work? I have both SP1 & SP2 forks at my house right now, and the SP2 forks are considerably shorter that the SP1's. I assume you used the SP1 lower triple clamp...?
Old Jul 14, 2009 | 09:10 AM
Fastest Color
irocker, I used CBR954 triples which push the legs down quite a bid since the 954 legs are even shorter than the RC51 SP2s it work's perfectly
https://www.superhawkforum.com/forum...rc51+fork+swap
Old Jul 14, 2009 | 09:35 AM
SlowHAWK's Avatar
Off hand.... I think I have my forks (SP1) 17mm above the triple... measured at the top of the fork tube, below the fork cap. I'm running a RC51 upper, which is flat, and I believe the 954 triple has a 12-13mm drop (in the gullwing area)... therefore your looking at 29-30mm from tree to top of fork tube (not counting the cap).
I can verify my dims tonight... I got the measurement from another member who did the swap as well, and I haven't moved the forks since... (I think I got it from RCVTR)
You'll find that this measurement will leave just enough of the fork exposed to **** you off as I found it was about 5mm short of being able to mount my clipons above the triple!!!! That's why I went with the RC upper in the end.
J.
Old Jul 14, 2009 | 09:38 AM
I noticed with the 954 triples that the fatter part of the SP2 leg was too low for the clamp . The fat part of the SP1 legs come up much further.
Old Jul 14, 2009 | 12:04 PM
cliby's Avatar
J.
I had almost the same measurement using the SP1 top (flat) clamp. So if you measure across with a straight edge daniel you shoudl be able to figure it out.
FYI
I think the SP2 difference in measured length is a bit of an artifact of the longer top out springs being used and thus sag is measure differently. In practice the effective length shoudl be about the same.
bc
Old Jul 14, 2009 | 12:49 PM
What you do is with the old forks still on there, you remove the wheel and put the axle back on, and measure from the frame to the axle. Then when you put the new forks on you put the axle in and raise the forks in the triple till the axle is the same distance as you measured on the old forks.
Old Jul 19, 2009 | 08:02 PM
KC-10ENG's Avatar
Nice looking project! I also have a RC swap on my hawk, I too am using a RC51 upper and a 929/954 lower triple. I think that the TL1000 Heli's are some of the taller ones that Heli makes for our fork diameter!
Dennis
Old Aug 2, 2009 | 12:36 AM
hondavtr1000sp2's Avatar
Hi,nice job.Iv got a 2002 Firestorm & 2001 SP1 forks/triples.Can you tell me what bearings you used to fit the SP1 forks to your vtr?
Old Aug 2, 2009 | 08:24 AM
All ***** Heavy-Duty Tapered Steering Head Bearings (22-1020) for the CBR954RR triple. The SP1 triples use a different bearing though.
Old Aug 3, 2009 | 12:43 AM
Ok,thanks for the info.Yes,another superhawk member told me i will need to use SP1 bearings for my SP1 triples.
Old Aug 22, 2009 | 12:59 AM
Has anybody modified the radiators to tuck the upper hose closer? Or did everybody just move the radiators back?
Old Aug 22, 2009 | 01:28 AM
As far as I know, nobody did any modifications to the radiators... I moved them back and down slightly following the lines of the fairing and then rotated the front hose a bit... Then added 2 mm to the steering stops which gave me nearly full lock without the forklegs hitting anything... Including the font hose and the fairing up around he handlebars...
Old Aug 22, 2009 | 04:47 AM
I just left the radiator hose in the stock location. The lower triple just barely touches and that is only at full lock. I'll be keeping an eye on it to see if there is any damage to the hose but after 1+ years of riding there is nothing yet.
Old Aug 22, 2009 | 06:39 AM
cliby's Avatar
same. no effect after 3 years+
Old Aug 23, 2009 | 09:01 PM
Finished... kinda. Edited original post.
Old Aug 27, 2009 | 10:06 PM
Well, I took her out to the "spars" for a little fun, but still found the rear-end acting like a wet noodle. For the most part, the bike was well planted with the Race Tech'd, stock legs, but now that the RC51 forks are on there the *** end is all over the place. When I did the swap, I measured from the bottom of the front axle to the bottom of the steering neck and got 29" ( I forget the measurement, but let's just say it"s 29"). I guesstimated another .25" shorter for the shorter triple offset and set the RC51 forks at 28.75".
I'm not sure what is causing the loose rear-end, but I'm pretty sure it has something to do with the forks since that's the only thing that's changed... it's like I'm riding around with a flat rear tire, but only when I'm in corners. I set the rear sag at 25 or 30mm a while ago, the front is set at 25mm. Should I drop the front end a little bit more, or is there something else I should be looking at? Suspension guru's, please chime in... Greg, Jamie, etc...
Old Aug 28, 2009 | 03:48 AM
I'm guessing you have the stock damper? If so, that's the most likely culprit... In stock form it's either snatchy and harsh or like you said "wet noodle"...
And yeah, it was kinda bad before my swap... Once the swap was done it felt like two different bikes...
Old Aug 28, 2009 | 05:33 AM
Fastest Color
+1, when I did my swap the stock rear shock's shortcoming were amplified, the I put a penske double clicker out back and life is good...
In the meantime, I'd raise the front end if you do anything to get you more stability out back...a braced swingarm helps too...
Old Aug 28, 2009 | 09:33 AM
Sorry, I should of specified... I have an Ohlins on the rear.
