airbox mod kit
Old Feb 13, 2007 | 07:56 AM
airbox mod kit
http://www.unlimited-power.net/angla...teproduits.htm
http://www.unlimited-power.net/angla...heVTR1000F.htm
Your thoughts?
Old Feb 13, 2007 | 02:18 PM
JamieDaugherty's Avatar
I'd have to see something better than the graph on their website. It looks way too smooth to be a real curve. Plus it's too small. From what I've read (people much more experienced with airbox mods than I) I doubt this works like they claim. How would a hole saw attack on the lid be any different? You don't need a filter because the holes are upstream of the standard filter. It sounds to me like you could just cut a couple of holes in your lid and see what happens. If it doesn't work you could just tape over them. Again, I don't think it would help, but that's just my opinion.
I wonder if they also have a "came shaft" that is "kick and easy to install". Ha!
Old Feb 13, 2007 | 03:50 PM
joshn569's Avatar
joshn569 is on a distinguished road
i wouldnt buy that
Old Feb 14, 2007 | 05:35 PM
shayne's Avatar
Well I have stuffed around with the airbox a bit and I am not sure of the results here. As there is no actual pic of the VTR installation, I assume the intakes are mounted in the lid the same as the other pic shown. This would place them underneath the foam on the underside of the fuel tank. This would seem to be not a good spot for them.
As for whether the concept would work or not, well maybe. Getting more air in is always good, however on the VTR when you do that you upset the operation of the vacuum slides, and you get a rough running engine under steady throttle. WOT is good though. I picked up 5hp with my mods, but not good on the street. Looked good on the dyno, and when you were on the gas. Cruising was not good though, so I went back to a more standrad set up.
I am considering a FCR conversion, so I f I do that I will go back to my modified set-up. The FCR should not have the issues of the OEM carbs.
Sep 25, 2011 12:06 PM
mikstr
Sep 5, 2011 07:13 AM
uchi
Aug 25, 2010 05:07 PM
mikstr
May 5, 2009 12:01 PM
99Timemachine
Jul 2, 2006 08:46 AM
