954 front end with stock wheel?
No, there are no bolt up 330mm rotors, you would also need to swap the bearings, grind some clearance in the middle of the wheel and make some custom spacers. (to fit the larger diameter axle)
Not sure if this will help, but I'm running 2001 GSX-R750 forks on my bike with the stock VTR wheel. These forks are Showa units and almost exactly the same as the CBR929 and 954 forks. The rotor diameter for them is Ø320mm, but luckily I was able to find something that works. The CBR11000XX uses rotors that fit the VTR wheel and are Ø310mm. Even though they don't match perfectly, after two years, including two full days on the track, they are fine.
It was a bit of a problem getting the wheel to fit but I'm really happy with it.
beloden
Sep 22, 2011 10:26 AM
Flight_996
Jan 6, 2007 04:19 PM
mrjakeanderson
May 31, 2005 11:18 PM
