929/954 Master Cylinder Swap
Old Jun 24, 2004 | 08:18 AM
mamisano's Avatar
Super Moderator
mamisano is an unknown quantity at this point
Did it, and wasn't sure at first. At the same time I also installed SS Lines and HH Pads.
The larger-piston Master Cylinder doesn't give any more braking power it just allows you to provide less force to the lever to engage the brakes. After I got used to the quick brake response, I really like it. Regularly use just 1 or 2 fingers to apply brakes.
I think the best thing to do if you have not done it is the SS lines and HH Pads. The M/C can come later.
If you get one used, remember to get the lever too as it is different than the stocker. They are visually the same so it does not look out of place, but the adjuster is totally different. Other than that, it bolts right on.
Old Jul 24, 2004 | 06:48 PM
Random's Avatar
Random
Re: 929/954 Master Cylinder Swap
I had done the pad swap, and SS brake lines, and a Race Tech fork rebuild, but still thought the front brakes were just too soft.
The 954 MC swap made a HUGE difference in initial brake "bite" and gave a much more progressive front brake performance.
I wouldn't pay "new" prices, but if you can get the MC off ebay or a local junkyard for $50, it's WELL worth it.
Old Jul 24, 2004 | 08:59 PM
mamisano's Avatar
Super Moderator
As Random said, you should pay around $50 for the MC off Ebay. They are hard to come buy, so keep your eyes out.
Old Dec 10, 2004 | 05:32 AM
Rollingalong's Avatar
Rollingalong
Can someone post the mastercylinder piston OD's for the SuperHawk vs 954 ?
I was doing some shopping but needed some baseline info for comparing .
Got the urge to lock the front at 100 or so if I want
http://www.hardracing.com/Brembo/BremboMC.htm
Jack Flash
Jan 6, 2014 07:11 PM
Lonewolf
Sep 2, 2012 01:14 PM
fundgh
Nov 16, 2009 02:22 PM
Killemall
Nov 7, 2007 10:05 PM
selztoad
Oct 18, 2007 05:03 AM
