900rr fork swap
Old Jan 13, 2012 | 06:15 AM
HRCA#1's Avatar
Angry 900rr fork swap
I'm going crazy trying to find the thread that has all of the fork conversions listed with the required parts.
I have a line on 94 CBR 900rr forks and want to be sure I buy the needed parts and what I recall is that this is a very straight forward swap. Just need to verify what I recall.
Also I seem to recall that a gullwing top clamp from another of the 900/929/954 family woks better at getting the bars "above the topclamp" pls help me verify by pointing me to the right threads.
Old Jan 13, 2012 | 06:20 AM
FL02SupaHawk996's Avatar
Fastest Color
Here's mine, but it's an RC51 conversion:
https://www.superhawkforum.com/forum...nd-swap-14855/
Old Jan 13, 2012 | 06:27 AM
slo1's Avatar
slo1 is on a distinguished road
900rr everything. Gull type 929/954 top triple would be a bit big in the hole department.
Old Jan 13, 2012 | 06:28 AM
This is probably the thread you're looking for:
https://www.superhawkforum.com/forum...p-guide-23751/
929 and 954 are USD forks so completely different from 900rr
Old Jan 13, 2012 | 09:03 AM
HRCA#1's Avatar
Thanks 7moore7 that's not the one I had in mind but it will certainly do the trick!!
Another question...the 94CBR900 forks differ slightly from 96,97 I hear it's lacking external compression damping anyone shed any light on that or other differences?
Old Jan 13, 2012 | 09:31 AM
Yes, and it's also considerably lighter sprung, so unless you are lightweight, you will need new internals on the new forks, otherwise it's not an upgrade compared to stock...
Old Jan 13, 2012 | 10:09 AM
HRCA#1's Avatar
Thanks Tweety,
I figured I would have to do that anyway, but after reading your info the later forks are probably closer in spring rate as I am 190lbs. Oh well looks like I'll be buying springs after all!!
Old Jan 13, 2012 | 11:59 AM
lloydievtr's Avatar
road racer v2 power
you want 94-97 forks 97 are better and you will need triple clamps
wheel spindle and spacers
front fender and brackets
after market clip ons or top yoke conversion to use renthal bars
be a good idea to replace fork bushes seals and springs and you will need to make a new
fork spring spacer (ali tv Arial tube works very well and its cheep)
5w oil
and head race bearings
and up grade the brakes wile your at it cbr600f4i calipers and master cylinder are the best to use
Old Jan 13, 2012 | 01:05 PM
Ons'Ro's Avatar
Ons'Ro is on a distinguished road
How do you tell the year of a particular set of forks? I found a stamp on the inside of the slider. It is circular with a 5 in the middle. Would that be a '95 set up?
Also, does anyone know what year 955 front fender one would use or are they all the same. And, just to make sure, you use all 955 mounting hardware/brackets, right?
Old Jan 13, 2012 | 01:17 PM
slo1's Avatar
Look at the lower fork leg. If there is an adjustment screw (compression) right below the lower caliper mount they are 96-97 (98 & 99 too ?). If not they are ealry (94-95) and are rebound only (screw at the top on the preload adjusters). They will all work in 900rr triples, but be sure they are pre 98 as the fork spacing changed which will wreak havoc with wheels/calipers/rotors.
Old Jan 13, 2012 | 01:36 PM
Ons'Ro's Avatar
So, I would want to re-spring for my weight no matter what spring is in there if it is a stock spring. And, how would one tell if the spring is stock?
Old Jan 13, 2012 | 02:46 PM
HRCA#1's Avatar
Question
5w oil
Talk to me about the top yoke conversion..is that to go with old school superbike bars? And what the hell are Ali tv arial tubes?
Old Jan 13, 2012 | 03:08 PM
https://www.superhawkforum.com/forum...version-19071/
900RR forks got compression adjustment in 95. 98-99 have different triples (10mm wider span between stanchions, different offset, different caliper mounts to accommodate 310mm rotors)
Old Jan 13, 2012 | 03:27 PM
Ons'Ro's Avatar
I see you have this conversion mikstr. Do you have the cbr fender or 955 fender? How much rise is in the Apex clipons? And, if '95 has a different spring rate than the '96-97, how do I know what year I have? Are the years wound differently? Are the springs a different lenth? My set does have compression adjustment.
Old Jan 13, 2012 | 06:18 PM
I have a 955 carbon copy fender (ran an OEM 955 fender for a couple of years, however). The stock 900RR fender is hideous IMO.
As for the internals info, regrettably I don`t have that info, sorry. Have a look at the Racetech site. My looking up in the Gold Valve kit and spring section, you can see the OEM spring rate (is listed for each bike).
I think my Apex risers are the 3" version, set almost to max (giving me essentially the same position and VTR1000 Helibars).
Hope that helps.
cheers
Old Jan 19, 2012 | 02:21 PM
kbyers's Avatar
CPT Obvious
kbyers is on a distinguished road
mikstr knows what he is talking about, I bought the parts for my swap from him. 96/97 forks are easy to find on ebay if you are patient. The ones that I found needed to be rebuilt so they got sent to Jamie and I will have forks set up for me when I get them back. If you are going to do a swap to increase performance you might as well get the most out of it that you can
Old Mar 7, 2012 | 12:02 PM
reg1972's Avatar
reg1972 is on a distinguished road
Question
Ahh some one that speaks from experiance I hope.
I have just done the conversion to 98 fireblade forks.
A local guy made up my wheel spacers for the VTR wheels and a set for some CBR600 wheels.
I have noticed my Rotors are to small by around 10mm !
Now I have been told that rc30 rotors are the way forward.
Could I please get some advice before I buy the RC30 equipment.
thedeatons
Aug 2, 2013 04:40 PM
HRCA#1
Jan 29, 2012 12:15 PM
Dan C
Jul 25, 2011 11:18 AM
taskmasta
May 19, 2008 09:25 PM
mikstr
Apr 18, 2008 03:03 PM
