50mm Clip-On's For RC51/954/929/1000RR Fork Swap - What Did You Use?
Old May 23, 2009 | 11:59 PM
Trying to figure out which route to take as far as clip-on's for my RC51 fork conversion. I'm somewhat interested in the Swatt bars but am concerned that I won't be able to get/make my Throttlemeisters to work with them. I'm not really too interested in super bike bars at the moment. I've searched quite a bit but have only found old threads with limited information. What have you guys used? Photo's would be a plus.
Old May 24, 2009 | 02:27 AM
I ended up using ConvertiBars as I was cramming my CBR 1000RR radial M/C in there and with every fixed solution something hit somewhere...
Other solutions that should work fine is Helibars, the CBR 1000RR heli's are 50mm...
Tomaselli's also have a 50mm option... You already mentioned Swatt...
Old May 24, 2009 | 06:41 AM
Swatts are standard hollow 7/8 in (I think that is what it is) bars.
They come with no holes in them etc, I drilled them as needed to make all my switch gear fit where I wanted them. I can't think of any reason your throttlemeister wouldn't work on them.
You are welcome to swing by and take a peek at them to see if they'd work for you. I would offer to ride up and meet somewhere but... I won't be riding for a while. :P
Old May 24, 2009 | 07:47 AM
Gregw's Avatar
I made my own. Here is a shot of them going on.
Attached Thumbnails 50mm Clip-On's For RC51/954/929/1000RR Fork Swap - What Did You Use?-cimg2131.jpg
Old May 24, 2009 | 08:11 AM
Yeah... But you are even more of a nut-case than me...
Old May 24, 2009 | 09:32 AM
Gregw's Avatar
True, but I didn't have to cut my fairing. No more achy hands too.
Old May 24, 2009 | 09:39 AM
How much rise do those have?
Old May 24, 2009 | 10:44 AM
cliby's Avatar
I tried about everyting available at the time, now using superbike bars which I like. Convertibars allowed the most fine tuning, but I always felt they were relatively complicated and clunky appearance (and $$). If I were going now with clip on style I would definitely look at either the Tarozzi's options or SWAT bars. Even at the expense of a throttle meister, I'd just switch to the simple vistacruise style - having both the appearance is nite and day but I honestly thinkg the $25 vistacruise is better functionally.
good luck
Old May 24, 2009 | 11:07 AM
SlowHAWK's Avatar
I used Ducati 900 SS Helibars.... they have a lot of rise to them, so you could easily use a RC or 929/954 upper triple and still get these bars in a good spot.
Attached Thumbnails 50mm Clip-On's For RC51/954/929/1000RR Fork Swap - What Did You Use?-ducati-900-heli.jpg
Old May 24, 2009 | 07:50 PM
Gregw's Avatar
It is 3½" from the top of the fork clamp to the middle of the bar inner end. Does that make sense?
Attached Thumbnails 50mm Clip-On's For RC51/954/929/1000RR Fork Swap - What Did You Use?-cimg2126.jpg
Old May 24, 2009 | 08:00 PM
Makes perfect sense with the photo! Thanks!
Old May 24, 2009 | 09:19 PM
That's the same rise as my Swatts, but with your design your bars are further back than mine, so you have a more upright seating position (not that mine is all that racy)
Old May 24, 2009 | 09:39 PM
Hey Lazn, do you have any fairing interference with the Swatt's? Are they flush with the underside of the triple clamp?
Old May 24, 2009 | 09:41 PM
No, and yes. I have them fully flush with the bottom of the upper triple, and to prevent any fairing interference I have them rotated slightly backwards. (about 1/4 inch from as far forward as they could go)
Setup like this there is no interference at all and the reach is quite comfortable.
Old Aug 1, 2009 | 10:30 AM
I bought some 2.5" rise Swatts as a temporary solution, possibly permanent depending on how well they work. Does anybody else have some 50mm clip-on's they might consider selling? I'd like something where the bar exits on the side of the clamp rather than the front. If I remember right, the TL1000S Helibars exited on the side.
Old Aug 1, 2009 | 11:02 AM
Syclone's Avatar
Boosted
/\ That's my only issue with the Swatt's. I ended up drilling and tapping a bolt into the left steering stop on the lower triple to ensure that my brake lever wouldn't hit the fairing. I had to swap the riser bars side to side too in order to mount my F4i M/C.
NooB
Mar 22, 2011 08:00 PM
vtromey
Apr 5, 2007 04:09 PM
Flight_996
Jan 6, 2007 04:19 PM
Speed_Demon
Mar 10, 2006 01:39 PM
Speed_Demon
Feb 2, 2006 09:00 PM
