-1 front, +2 on the back
I got one of these to try when I do the 520 conversion
Alloy carrier, steel teeth ring, & titanium pins - about $85
Should give good sprocket wear but lighter than full steel
Heavier than aluminum tho but i prefer better wear
http://www.drivesystemsusa.com/p/351...ket-honda.html
Can you simply replace the out ring when it wears out? Can you get in a couple different sizes for less than entire sprockets? I like the idea, thanks for bringing it up.
Hey internet tuff guys, new info comes up every time a topic is covered. The search function sucks. If searching was so easy, they wouldn't have created sticky's or white papers, so back off. Why waist your time posting a complaint, if you don't like the thread don't enter. New people join with new input. Ever try searching for the front end swap and find different information in every thread? People were posting in 2002, and had nowhere near the information we have in 2008. Get over it.
Being steel teeth, when it's time to change the sprocket you would need a new chain & front sprocket anyway
I did the 15/43 set up a few weeks ago, lots of fun playing around. I just got back from the twisties with this set up, way to choppy, think I'm going back the stock front and +2 on the rear.
care to expand on "choppy" like you couldn't keep the front wheel on the ground?
This is an interesting discussion, but I have a few questions;
What is the best motor oil for my Superhawk?
What is the best rear tire for winning a race with my buddy and his 2006 Yamaha R1 LE?
Should I install the Dynojet or the FactoryPro jet kit?
What are the best slip-ons and which air filter should I use?
Why would a guy from Athens keep insisting that "This is Sparta"?
I mean come on, Athens is in Georgia. Everybody knows Sparta is in New Jersey.
the advantage of 520 is lighter, but lighter is not just lighter as a lighter seat or tank,etc., when it involves spinning weight, and unspung weight. Chain/sprockets are incredibly more significant, as are lighter wheels, tires, rotors. Centrifical and Gyroscopic effects and principles apply. If you're not into performance, that is acceleration, deceleration, bending turns, etc., then use the OEM set up because heavier is stronger in the case of 520 vs 530, and you will probably achieve longer duration with less adjustments.
old thread but what is this buzzy in 6th about. I have never figured out this noise I have in 6th and wondering if it's related.
VThokie412
Nov 13, 2011 11:00 PM
pzurek18
Feb 26, 2009 08:41 PM
mdbuehler
Feb 5, 2006 07:51 PM
