Where do I begin???
Old Mar 20, 2010 | 09:17 AM
  #31
NakedOne's Avatar
NakedOne is on a distinguished road
Kai, I try to tell my wife about the my bike and she gives me the same response. LOL! All I can do is stare at it now cause there is all kinds of snow on the ground. What other mods have you all done?? I need all kinds of ideas.
Old Mar 24, 2010 | 11:35 PM
  #32
poppazuti's Avatar
Head Scratcher
Update? What have you decided to do so far?
Old Mar 25, 2010 | 04:20 AM
  #33
luis saleiro's Avatar
luis saleiro is on a distinguished road
Hi,
I´ve been reading with all the attention cause i´m in the same kind of obsession as you are.
I´m into turning my 97 vtr to naked with a fat bar and keeping the cluster (it´s important to me to keep it). I recon this is a problem already cause the cluster is a big far from the bike front and might turned a bit uggly.
This brings a doubht with the headlight, and what kind of it will be. Single, dual or with a windscreen.
Personnaly i love the look of the speed triple with the dual headlight, but its a bit expensive and hard to put together with the cluster, as well as hidding the stock wires.
It´s a hard job if you want to get it nice.
Keep the news coming, i´m looking forward to see some pictures.
Old Mar 25, 2010 | 05:01 PM
  #34
crazy1's Avatar
crazy1 is on a distinguished road
another vote for the trail tech vapor
had this one on 3 bikes before i had to let it go with one of em.
http://img169.imageshack.us/img169/3929/nt650.jpg
http://img179.imageshack.us/img179/3929/nt650.jpg
Old Mar 26, 2010 | 07:37 PM
  #35
NakedOne's Avatar
Well i havent got around to doing anything yet due to the late winter snow. I will post before pics as well as after pics of my naked project. I think im gonna just fab up a mounting bracket for the speedo and get some headlight mounting brackets and go from there. I was looking at the harness and there is a lot of extra length to the headlight which may be a problem to make it a clean look. As it is I will keep the posts updated and hopefully some pics as well. Any ideas on how to clean up the harness?
Old Mar 26, 2010 | 11:06 PM
  #36
poppazuti's Avatar
Head Scratcher
It will require a fair amount of trimming and the remainder can go inside the headlight bucket. Still working on mine, though. I'll let you know what I figure out.
Old Mar 26, 2010 | 11:25 PM
  #37
NakedOne's Avatar
Cool, any info will help and if for some reason I can help with what im doing I will.
^^^Do you have pics of your project?
Old Mar 27, 2010 | 12:12 AM
  #38
kai ju's Avatar
My excess harness is coiled up behind the steering head area and secured to the crossbrace in front of the airbox. Just make sure that it can't move to block the snorkel for the airbox.
The drawback was that I had to lengthen the gauge harness, but everything else ended up very clean and tidy.
Kai Ju
Old Mar 27, 2010 | 08:31 AM
  #39
NakedOne's Avatar
Kai,
what headlight brackets did you use to mount your single?
Old Mar 28, 2010 | 08:26 PM
  #40
poppazuti's Avatar
Head Scratcher
Two in my profile. I've been meaning to get some more and upload them, just short on time.
Old Mar 28, 2010 | 10:38 PM
  #41
NakedOne's Avatar
Nice Poppa, what exhaust do you have on there? How is the progress on the headlight brackets?
Old Mar 29, 2010 | 10:04 PM
  #42
poppazuti's Avatar
Head Scratcher
The exhaust is/was a Jardine rt1 highmount. I shortened the cans 6" and cut the midpipe flange off the left side and had a hole cut on the right midpipe and welded on to it (done at local exhaust shop for $90). A friend chopped off and capped the left header. I actually wanted the cans to sit closer to each other but with passenger footpegs on the spacing is perfect, so I'm really happy with the end product.
The headlight brackets should be done this week. My buddy picked up some scrap pieces of aluminum at work and just needs to weld them on.
Truth be told, that should have been my first piece of advice...if you're not good at welding or metal fabrication, make friends with someone who is. Between my Jeep and bike my friend has saved me so much money.
Old Mar 31, 2010 | 11:20 AM
  #43
NakedOne's Avatar
So last night was my first night ride and my current headlight situation sucks. What can i do to make my lighting brighter?
Old Mar 31, 2010 | 12:05 PM
  #44
Relay mod, better bulb, or go all out and HID conversion.
Old Mar 31, 2010 | 01:13 PM
  #45
poppazuti's Avatar
Head Scratcher
+1 on better bulb. I tried the sylvania silverstars on my stock setup with good results. If you're planning on going with another headlight you could bite the bullet and save your $ until you know exactly what your plans are. Or buy the lights in a pair and use them on any h4 setup you may have on a car if you decide to go with another setup on the bike.
Old Mar 31, 2010 | 02:40 PM
  #46
FYI the best rated prebuilt relay kit is: http://www.easternbeaver.com/Main/Pr...s/h4_kits.html
I just made my own, but it wasn't any cheaper, just no shipping time.
Old Mar 31, 2010 | 08:06 PM
  #47
NakedOne's Avatar
I was looking at the aztec8 dual headlight kit that plugs into your stock harness. It claims that the bulbs are 55w x 2 so what would that do to the actual power draw and is that an actual safe way to change?
Old Mar 31, 2010 | 11:53 PM
  #48
I´m still folowing you with all the atention NakedOne.
You´re doing very good questions.
I´ve just ordered my dual headlights like those in aztec8, they will probabily be here in 2 weeks.
And i´m having exactly the same questions as you are now.
Keep them coming man.
Does anyone knows what the 55w x 2 would do to the actual power draw and is that an actual safe?
Plus, is it a plug and play work, or will we have to "eliminate" any wires?
Old Apr 1, 2010 | 09:01 AM
  #49
Well I am sure it will work.. But since the stock harness is already too weak for the one stock bulb, I would get a relay kit as well. Otherwise they will just be very dim.
Old Apr 1, 2010 | 11:51 AM
  #50
NakedOne's Avatar
So I was checking on some relay kits and there all about $40-$50 bones. What is the cheapest way to use the dual light setup and get the correct light output safely?
Old Apr 1, 2010 | 01:55 PM
  #51
Well I did it myself with autopart store parts:
lengths of heavy gauge wire, 2 colors: $14
2 Relays: $15
H4 plug: $5
Connector into stock plug: $5
6A diode to keep low beam on when High beam is on: $7
Solder: on hand
So all in all I spent ~$46+ tax for a bulkier homemade version when I could have gotten a premade micro relay kit from Eastern Beaver for about the same amount.
Now if you already have some thick wire and auto relays laying around you can do it for less.
Old Apr 1, 2010 | 03:46 PM
  #52
NakedOne's Avatar
Nice, thanks for the info! Does anyone have any pics of the dual headlight setup on a stock harness?
bmidd
Nov 10, 2013 08:17 PM
WOMPY5000
Jun 28, 2012 01:36 PM
3Dcycle
Apr 1, 2011 05:52 PM
Malice
Sep 21, 2009 06:50 PM
bronco78
Dec 7, 2005 03:16 AM
