What's involved with painting/prepping the stock fairings?
Old Sep 16, 2009 | 06:45 PM
Just_Nick's Avatar
Who are you?
So my bike has a decent paint job, no not stock, however I am picky and want a nice paint job.
So what is involved with prepping the stock fairings? Can you use chemical paint stripper or do you have to sand it? And how far down do you have to sand it?
Also, what grit do you recommend?
Old Sep 16, 2009 | 09:58 PM
Stay away from paint stripper on plastics. To get a solid paint job is a pretty in depth process... it would take forever to type out every step. How much painting "know how" do you have?
Old Sep 17, 2009 | 07:55 PM
Just_Nick's Avatar
Who are you?
I have confidence in my painting skills, so all I need to know what is required for prepping the fairings for painting.
Old Sep 17, 2009 | 09:51 PM
RCVTR's Avatar
The fairings have a lot of curvature everywhere, so it's probably best to stay away from an orbital sander. I'm preping my RC51 bodywork for paint now. The lower fairing survived, the rest is new, but I also painted my VTR bodywork.
Basically, you are looking at wet-sanding, until you're sick of it, then wet sanding a lot more. I started with 180 grit. You could start courser, but it tends to put deep scratches in that are hard to sand out. I'mnot trying to remove all of the paint, but I also don't want to just cake on more layers. I sanded all the clear off and a good portion of the base paint, using 180 grit.
Next is filling the rock chips and scratches with a light filler, called glaze coat. Then wet sand everything with a finer paper, say 280 grit. Sand until everything is blended and smooth.
Then use a good, sandable primer. A couple of thick coats (enough to wet the surface, sithout running). Then wet sand with 400. I usually sand again with 600. Not sure if that is necessary. At that point you should have a perfect, paintable surface.
For the tank, I strip it to bare metal, with a chemical stripper, then sand it with 180 and 280 grit. It's very important to use an etching primer on the tank. You can buy it in a rattle can at an automotive paint store. Wet sand it and apply the sandable primer, then prep the same as the bodywork.
It takes a while, but it's pretty satisfying in the end, if you are thorough in your preparation.
Old Sep 19, 2009 | 07:40 PM
Just_Nick's Avatar
Who are you?
Now what color should I go for?
Old Sep 19, 2009 | 09:05 PM
Gregw's Avatar
Here is a site that may drive you mad with options.
http://www.alsacorp.com/index.htm
Spawnbike
Jan 4, 2014 01:54 PM
joshuatest
Oct 25, 2008 04:03 PM
midijunky
Sep 15, 2007 01:28 PM
barrysuperhawk
Apr 2, 2006 12:55 PM
Rufion
Feb 13, 2006 12:02 PM
