What swingarms will work?
Old Aug 9, 2006 | 12:33 AM
Wraith's Avatar
Wraith is on a distinguished road
Okay, i've been searching for the answer to this, and am coming up pretty much dry...
I would like to do a VFR800 conversion, but has anyone attempted to use a 600RR, or one of the other Honda swingarms, in a somewhat direct swap? I find it hard to believe that the VTR swingarm was only used on the VTR...
Trey
Old Aug 9, 2006 | 03:41 AM
hawxter996's Avatar
ole dirty bastard
this one works,....................with a little work!
Old Aug 9, 2006 | 07:55 AM
RCVTR's Avatar
600RR?!?!
Careful there.
It's true the VTR swingarm was only used on the VTR.
Old Aug 9, 2006 | 08:00 AM
hawxter996's Avatar
ole dirty bastard
Talking
rc51 arm, why careful?
working on linkage
neeeed more parts!
Old Aug 9, 2006 | 08:52 AM
superhawk22's Avatar
You'll run into a lot of fab work because the VTR swingarm is shorter than most and the linkage is so much different.
Old Aug 9, 2006 | 09:00 AM
hawxter996's Avatar
ole dirty bastard
Talking
i have a plan!...........(devlish laugh.)
Old Aug 9, 2006 | 12:54 PM
Wraith's Avatar
Well, all roads are pointing to the VFR swinger... Luckily enough, I don't have to worry about the top shock mount - custom frame...
Trey
Old Aug 9, 2006 | 03:21 PM
hawxter996's Avatar
ole dirty bastard
rc51 will work just as easily.
both require work to get there.
929 and 954 can work also i believe.
Old Aug 9, 2006 | 06:35 PM
superbling's Avatar
Trey
Why?
It's the only bike (honda) that I can think of that bolts to the engine case and not the frame.
Old Aug 9, 2006 | 10:39 PM
Wraith's Avatar
Why?
VFR...
Trey
Old Aug 9, 2006 | 10:50 PM
EngineNoO9's Avatar
vfr is a sss and still requires work. it isn't a simple "I have a vfr swingarm, let's throw it on today to see what it looks like"
Old Aug 10, 2006 | 02:59 AM
ondrevtr's Avatar
ondrevtr is on a distinguished road
I have done VFR 800 swingarm conversion and it looks great..see my pix in thread about installing VFR swingarm.
I assume that all Honda swinarms would work as long as they are meant to be attached to engine, not frame?!
O.
Old Sep 18, 2006 | 11:08 AM
redlinetech's Avatar
redlinetech is on a distinguished road
Is this conversion hard? Special fab work? Problems or Limitations.
Old Sep 18, 2006 | 01:27 PM
killer5280's Avatar
Why?
954 and 929 also had this arrangement, didn't they?
Old Sep 18, 2006 | 02:55 PM
Nope, like most sportbikes the swing arm is bolted to the frame not the engine. The SH is one of the few where the engine is a stressed member.
HAHAHAHA he said MEMEBER!
Old Sep 18, 2006 | 03:09 PM
hawxter996's Avatar
ole dirty bastard
Talking
Originally Posted by superhawk22
Nope, like most sportbikes the swing arm is bolted to the frame not the engine. The SH is one of the few where the engine is a stressed member. sorry to correct you but the 929 and 954 did not attach to the frame . they had a casting that wrapped under the engine. look it up
Old Sep 18, 2006 | 06:53 PM
JamieDaugherty's Avatar
I've got CBR929, CBR600RR and many other swingarms here and I can say none of them are very close. All would require machining, welding, fabrication, custom bearings, frame modifications or all of the above. Unless you have access to a TIG welder and a full machine shop you probably want to think about doing something else. If you do, then go for it!!!
Old Sep 19, 2006 | 05:03 AM
hawxter996's Avatar
ole dirty bastard
Jamie,
of all the swingarms mentioned rc51 appears to be easiest. dont have to move shock like on the vfr800 swap. and you dont have to mod the exhaust either. you do have to make new linkage though. i just need to finish mine.
mike e.
Old Sep 19, 2006 | 06:02 AM
SlowHAWK's Avatar
hawxter996....
My understanding is you need to relocate the swingarm pivot location on the RC swingarm (move it backwards towarsd the tire).... are you saying that's not the case, and it's basically bolt on with a few spacers and the custom linkages?
J.
Old Sep 19, 2006 | 10:04 AM
hawxter996's Avatar
ole dirty bastard
Originally Posted by SlowHAWK
hawxter996....
J.
it really depends on how **** you are. i have to research what spacers ive used. but the combination ive come up with puts the arm right where it needs to be. i have verified the wheel alignment and it came out perfect.no need to move shock or fab new exhaust.you will have to mod the left side superhawk roller bearing spacer,needs to be made shorter or just use the 51 item with an additional spacer.now remember this is the SP2 arm the SP1 will not fit.im going a little crazy on mine, im going to fab some plates to allow me to use cbr or rc rearsets.im also working on an under tail exhaust that i will reveal when im happy with the fit. im not to worried about the extended wheelbase just yet,but that may change later. im kinda going for a combined moto gp, suzuka endurance look. just trying to decide what style body work.
Old Sep 19, 2006 | 02:00 PM
I've not tried an RC51. I did measure my friend's bike and it didn't look very close. The key is not to just make it bolt up but rather to maintain the wheel centerline. Just fitting it on there is not the hard part, most of the time the mounting points need to be shifted side-to-side keep the wheel on center. This is the hard part. If I can find an RC51 swingarm on eBay within my budget (cheap!) then I might give that a shot.
Old Sep 19, 2006 | 03:02 PM
hawxter996's Avatar
ole dirty bastard
Jamie,
check my previous post. i have verified centerline.
mike e.
Old Sep 28, 2006 | 07:26 PM
2Phaast's Avatar
2Phaast is an unknown quantity at this point
Just a thought.... After adding the 900rr bracing to my swingarm, I have a slight clearance prob on left side with the exhaust..... I got the Two Bros full system w/ high mounted carbon fiber cans, and the front of the cans slightly touch the bracing.... a bit of adjusting and it isn't so bad... may not be any such prob with other cans and stock exhaust or another full exhaust system.
Old Sep 28, 2006 | 07:35 PM
EngineNoO9's Avatar
quick question about the rc51 swingarm. how much longer does it make the bike? Also I assume with the swingarm the superhawk shock just bolts right up correct?
Old Sep 29, 2006 | 02:08 AM
mr.billet's Avatar
mr.billet is on a distinguished road
The rc51 swingarm is about 3in longer than your stock vtr swingarm. If you look under my posts you can see how I went about fitting it to my vtr.
Old Sep 29, 2006 | 02:55 AM
hawxter996's Avatar
ole dirty bastard
actually you are quite vague on how you mounted it.
Old Sep 29, 2006 | 03:37 AM
hawxter996's Avatar
ole dirty bastard
no not a bolt on you have to fab new linkage for the shock.and different spacers for the swingarm to mount to motor.
Old Sep 29, 2006 | 03:53 AM
Check out swingarm.com. JMC makes some pretty cool stuff if you have the $$$.
Old Sep 29, 2006 | 07:42 PM
mr.billet's Avatar
In the 9th post under my posting "couple pics of my superhawk" explains how I fitted it to the bike. Other than starting over again and digitally documenting it step by step, what more do you need to know? If someone has the time and money I am willing to do it again.
Old Sep 30, 2006 | 06:48 AM
hawxter996's Avatar
ole dirty bastard
Thumbs up
some of us were just hoping for some more detailed photos is all.
especially of your linkage . im mostly done with my linkage just curious how you did yours.
not to worried about length of arm,just yet.
finishing linkage and my exhaust design is 1st priority.
just need to find someone to weld this stainless tubing.
jscobey
Sep 22, 2014 12:57 PM
seb421
Sep 1, 2012 01:12 PM
eezz
Jul 9, 2012 03:04 PM
trident00
Jan 12, 2011 08:36 PM
Hawkrider
Jun 14, 2006 11:39 AM
