volar integrated tail light
Old Jul 9, 2011 | 05:36 PM
CptCrunch's Avatar
HIGH-SPEED
CptCrunch is on a distinguished road
ok.. I searched the forum and couldn't find the similar problem.
I am installing a volar integrated tail light and I came across a problem when trying to plug the blinker wires in..
the running light and brake lights work when plugged in.. but when I go to plug in say the left side blinker that side of the running light shuts off so only half of the tail light is lit up but the blinkers will still work when i turn the blinker on (same for the other side)
anyone else come across this problem or have a possible solution?
thanks in advance!
Old Jul 9, 2011 | 05:42 PM
K30's Avatar
K30
K30 is on a distinguished road
Same taillight, same issue. Geekonamotorcycle said he fixed his by swapping the two power leads. I have yet to try it, but might do it in a bit and report back with what I figure out.
Old Jul 9, 2011 | 05:49 PM
CptCrunch's Avatar
HIGH-SPEED
yeah I tried that and it didn't work.. the tail light works fine.. its just when I plug the blinker wire in that side stops working?
its starting to **** me off.
Old Jul 10, 2011 | 06:48 AM
RWhisen's Avatar
Former Superchicken Owner
Geek posted this on his blog. Check that the wiring on the tail light is correct.
04-07-11 Integrated tail light installation « Just a Geek On a Bike
Old Jul 11, 2011 | 11:36 AM
geekonamotorcycle's Avatar
Did that work for you? I found the contacts to be flipped on mine.
Old Jul 12, 2011 | 03:18 AM
CptCrunch's Avatar
HIGH-SPEED
No that didn't work I already tried flipping them.. I'm lost...
Old Jul 12, 2011 | 08:07 AM
I have no other ideas aside from plugging it into a power source to check it. it might be defective.
Old Jul 26, 2011 | 06:26 AM
sfjreid's Avatar
sfjreid is on a distinguished road
thanks in advance!
I just finished solving this same issue with my VTR. What I had to do was disconnect the wires for the running lights on the front signals. They will still work as signals but will no longer stay lit as running lights. I had about 4 hours of using jumper wires and a battery testing the unit and this what I ended up having to do. The tail light worked fine when using the jumper wires and the battery but when plugged into the bike I had the exact same issue. Hope this helps.
Old Jul 27, 2011 | 03:22 AM
CptCrunch's Avatar
HIGH-SPEED
Ok thanks I will try that!
Old Aug 1, 2011 | 04:36 PM
Stumpy's Avatar
Mine does the same thing just about to check it out thanks for the help in advance
SuperMike
Aug 8, 2014 07:46 AM
aaugsbu
Apr 18, 2011 06:18 PM
geekonamotorcycle
Apr 13, 2011 12:11 PM
mrmhrm9598
Apr 9, 2011 05:18 PM
seaton001
Mar 19, 2007 05:46 AM
