VHT Paint and Laquers
Old Jan 7, 2009 | 12:04 PM
AJG101's Avatar
AJG101 is on a distinguished road
Hey guys, wondered if anyone had some ideas on the following. I want to paint my front exhaust section with VHT paint. (very high temp). I then want to laquer it and also do the same to the engine casing. I'm concerned about heat dispersal from the engine and exhaust and any adverse effects doing this may have. Has anyone done it? If so what's the score? I may be worrying about nothing but rather be safe than sorry.
Cheers!
Old Jan 7, 2009 | 12:22 PM
zmaniv's Avatar
Jet hot coating is one option
Old Jan 7, 2009 | 01:02 PM
Wicky's Avatar
https://www.superhawkforum.com/forum...742#post193742
Check the VHT FAQ - Not sure why and if you can laquer (for glossy finish?) exhaust manifold close to the cylinder head - if you do, don't expect the finish to last long due to high temps. Best get it ceramic coated but again the glossier you want it the less it can be guaranteed.
http://www.performancecoatings.com/headercoatings.html
Satin Black finishes are OK to 2000 degrees
Old Jan 7, 2009 | 01:21 PM
AJG101's Avatar
Was after a glossy finish but understand why the heat exposure will make it dull and matt out. What's jet hot coating?
Old Jan 7, 2009 | 02:01 PM
Wicky's Avatar
As long as the surface is thoroughly prepared inside and out, the a Jet-Hot coating (metalic-ceramic) or ceramaic finish will outlast and outfinish a painted finish.
A bit dearer but you pays your money and takes your choice....
http://www.carcraft.com/techarticles...ngs/index.html
Old Jan 7, 2009 | 06:09 PM
mboe794's Avatar
I have wrapped headers topped off with black VHT. The paint has been holding up great on there. Its been on since spring. The temp. just at idle reaches nearly 800 degrees, I checked with an infrared thermometer. So i don't think there is anything to worry about with the paint. The laquer however I have no experience with.
wsharpman
May 7, 2012 09:03 AM
j shizzy wizzy
Feb 7, 2009 12:18 PM
mikecronis
May 4, 2005 02:20 PM
