Show us your aftermarket Bar Ends!
Old May 13, 2015 | 04:17 PM
thedeatons's Avatar
Mine are a faux carbon fiber by Lockhart Phillips... I don't really care for them.
Show me yours! Whatcha got?!!?
James
Old May 13, 2015 | 04:50 PM
Got these from the UK eBay. The LED's could be a bit brighter. In the daytime, they are a little hard to see. When I switch to my '07 CBR1000RR front end, I am using Danmotto clipons, which don't allow me to use any aftermarket bar ends, so these will have to go. Darn...
Old May 13, 2015 | 05:48 PM
scottiemann's Avatar
I'm running bar end mirrors...
Old May 13, 2015 | 07:02 PM
me too..... these: Motorcycle CNC Aluminum Rear View 3" Handle Bar End 7 8" Mirrors Round Black New | eBay
Old May 13, 2015 | 07:05 PM
oooh those are nice ... I'm running mo cheapo bar end mirrors but I'm thinking about upgrading once the dust settles lol
Old May 13, 2015 | 07:11 PM
thedeatons's Avatar
Anyone running a heavy steel aftermarket bar end?
I was checking out the Heavy HVMP bar ends.... Until i saw the $70 price tag.
May have to work on making some out of solid steel tubing....
James
Old May 13, 2015 | 07:16 PM
why heavy steel? are you looking for more vibration dampening?
Old May 13, 2015 | 07:18 PM
thedeatons's Avatar
Well, more than i have now, with these aluminum bar ends. I have lead diver weights slipped into the bars, just looking to add weight to the outer ends.
Anyone know what the stock bar ends weigh in grams or ounces?
James
Old May 13, 2015 | 07:32 PM
do you have a good drill press (I mean a GOOD one) and a precision vice? and lead laying around? If you dont want to spend any money, I suggest you drill holes in the perimeter of your existing bar ends and fill them with lead... that is if you like the look of your fo-carbon bar ends...
James, there are steel bar ends on eBay for about $25. I don't recall for sure, but I think there is at least one seller claiming to be made in the USA at that price point. I've looked at them, but I'm not settled on what I'm doing for bars, so they're not at the top of the list right now
Old May 13, 2015 | 07:36 PM
Check out eBay item 180663757314.
Ships from USA, at least, for $27.
They're made of steel and "weighted". Not sure what you weight steel with for bar ends? Maybe moon rock?
Old May 13, 2015 | 07:53 PM
thedeatons's Avatar
Yep, saw those, but i need a universal bar end with the rubber wedge type inner end, as the stock weight is not installed inside my handlebars.
Like i mentioned above, i have diving weights installed in the bars.
James
Old May 14, 2015 | 02:46 AM
Hey Mikstr,
Those mirrors you have are the same as the ones I have been posting about in the rant section, except the ones I still don't have are silver not black.
Ha ha, at least you have yours.
Good luck James !
Old May 14, 2015 | 09:33 AM
James
Yes I have two sets right now… not aftermarket, but from other model bikes, using these on my Apex bars and used them previously on the VFR bars I had.
Both are held in place with an aluminum split wedge I make.
One is an adapted set from a Triumph. They are fairly heavy @365 grams each and have an elastic rubber isolator between the center mount and the end weight itself.
The other set is from a Suzuki …. I honestly cannot remember which model though..
I picked up both as junk at my local dealer when they were replaced as part of an insurance job. //Little [paint stripping and some new powder coat, good as new.
Are you looking for looks? Vibration reduction, added lights?
sailorjerry
Sep 19, 2014 11:47 PM
Shawn Torpey
Mar 13, 2007 04:25 PM
gpz4jp
Mar 9, 2007 07:10 AM
NoCats
Nov 10, 2006 06:39 PM
Randman
Feb 3, 2006 10:40 AM
