Normal Bolt? / Frame Sliders
Old Apr 6, 2007 | 11:59 AM
Duck007's Avatar
Hola all.
Just put on the t-rex frame sliders now (couple pics because I couldn't find a decent one before I bought them). Anyway as you can see from the pic of the bolts, the funky one came out of the left side. I'm hoping that this crud is some sort of locktite, but it's not on the threads?? Not wet at all. Looks kinda like battery post corrosion.
Anyone else run across this condition? This is an '05 w/ 7300 miles.(I'm hoping not to hear that I have a leak somewhere).
Thanks!
Old Apr 6, 2007 | 12:45 PM
seaton001's Avatar
seaton001 is on a distinguished road
My bolts have the same corrosion on them. I think it is simply oxidation from from the aluminum in the motor cases plus some corrosion on the bolts themselves.
Old Apr 6, 2007 | 02:58 PM
sprhawk neil's Avatar
mine did not look like that but it could just be from moisture sitting in there? I would not worry to much
Old Apr 6, 2007 | 03:01 PM
MUHerdFan's Avatar
Mine looked like that when I installed my LSL's. I wouldn't worry about it since it is probably from moisture from sitting somewhere.
Old Apr 6, 2007 | 04:01 PM
jamesvtr's Avatar
jamesvtr is on a distinguished road
mine had the same corrosion. Just moisture and two dissimilar metals that cause a reaction dont worry
Old Apr 6, 2007 | 04:09 PM
Duck007's Avatar
Excellent. I'll be able to sleep now. Thanks!
Old Apr 6, 2007 | 05:58 PM
My linkage bolts looked like that when I put the Penske on mine. I polished them clean and glazed a coating of STP on them and reassembled everything. Steel and aluminum don't like each other!
Old Apr 6, 2007 | 07:09 PM
Commonly known as galvanic corrosion. Entirely normal.
Old Apr 7, 2007 | 09:15 AM
Birdoprey's Avatar
Bicycles have the same issue. The common cure is to put a light coating of grease or never-seize on everything. Of course, if it's something that doesn't need to slide you have to consider that.
Old May 22, 2007 | 09:17 PM
speed2's Avatar
speed2 is on a distinguished road
I have been looking for frame sliders that require no cutting and those look good where did you get those from???
Old May 22, 2007 | 09:50 PM
Firehawk_ordie's Avatar
Firehawk_ordie is on a distinguished road
there is a product called no-lox its a corrosion preventative found in the electrical department at home depot. Its made to be used on aluminum wire when being secured in aluminum lugs. It's supposed to prevent that kind if corrosion. a small squeeze bottle is about 5 bucks. however if you know an electrician you might be able to get some for free.
Old May 23, 2007 | 05:10 AM
StoneJrW's Avatar
StoneJrW is on a distinguished road
speed2
Squid Join Date: May 2007
"I have been looking for frame sliders that require no cutting and those look good where did you get those from???"
I got mine from ebay.
salmanilla2000
May 9, 2011 12:05 PM
salmanilla2000
Apr 27, 2011 10:41 AM
mikstr
Sep 25, 2010 01:01 PM
F1 Fan in Nascar Land
Jan 26, 2007 12:25 PM
mikecronis
Aug 17, 2005 05:58 PM
