Handlebar control swaps?
Old Apr 11, 2009 | 11:08 AM
mdbuehler's Avatar
mdbuehler
I can't seem to find the posts anymore, but I'd swear I'd seen somebody who'd swapped out the stock headlight / turn signal switches etc. for those off another bike. Anybody done this / know which ones work? Seems simple enough as putting the VTR ones on the 929 clipons was no problem. Hoping to get something slightly more modern looking and ergonomic for my '98!
Old Apr 11, 2009 | 12:17 PM
Erik S.'s Avatar
I'm swapping out a Superhawk headlight switch for a Firestorm headlight switch. Differences? On/Off button for the headlight and a Passing switch.
Old Apr 11, 2009 | 01:44 PM
VTRDenmark's Avatar
The vikings are not dead
VTRDenmark is on a distinguished road
Oh, I did not realize that there were so many different things from a SH to a Storm ..! Thought they were alike ?
Old Apr 12, 2009 | 06:23 PM
Erik S.'s Avatar
Minor things. I found this out thanks to members on this website.
Old Apr 12, 2009 | 10:21 PM
Where did you get the Fire Storm switch?
Old Apr 12, 2009 | 10:24 PM
Truckinduc's Avatar
ive got hayabusa switches. More modern looking and an extra switch ill be using to turn the lights on and off for cranking. also a handlebar mounted choke.
Ill be wiring them up in a few hours
Old Apr 13, 2009 | 01:05 AM
mdbuehler's Avatar
mdbuehler
I used to have a '99 Busa, those work? Thats great! Having the choke up high was way more convenient (and on that bike doubled as a cruise control as all it did was hold the throttle open). Let me know how that turns out and I'll be on Ebay right after!
Old Apr 13, 2009 | 10:25 AM
Truckinduc's Avatar
Its not direct, meaning its not plug and play. Im cutting the connectors off the old switches and soldering them in to the new switches.
Old Apr 13, 2009 | 11:18 AM
mdbuehler's Avatar
mdbuehler
After the CBR gauge swap, that'll seem easy enough My big concern was spacing (if they'd physically fit). Off to ebay I go...
Old Apr 13, 2009 | 11:23 AM
Truckinduc's Avatar
Oh I dont know if they will fit, Ive got mine on handlebars, not the stock clipons
Old Apr 13, 2009 | 03:03 PM
mdbuehler's Avatar
mdbuehler
I'll find out / make them one way or another. Barely $40 for a complete set of everything, and I'll have a few other random switches to use for whatever I find a need after I'm done (will get to add hazard lights too ).
Old Apr 13, 2009 | 03:36 PM
Truckinduc's Avatar
ya I used the hazzards to cut off my headlight and tail light, like when the bike is warming up.
The starter button is wired where it will cut off the headlight when the button is pressed if you wire it up that way.
Old Apr 14, 2009 | 10:40 AM
Erik S.'s Avatar
Found them on www.ebay.co.uk You're US account should transfer right over.
Search for "Left hand switch". I think I paid 17 Pounds, about $40 US after shipping.
Old Apr 17, 2009 | 04:19 PM
mdbuehler's Avatar
mdbuehler
Left side controls showed up today, and I found the Busa wiring diagram online. Should be easy enough, so I'll give this bit a go this weekend.
Old Jan 26, 2010 | 11:00 PM
102dals's Avatar
buehler,
How did this work out for you?
Old Jan 26, 2010 | 11:01 PM
102dals's Avatar
Erik,
Did the switch plug directly in?
Old Jan 27, 2010 | 12:30 AM
mdbuehler's Avatar
mdbuehler
It went very well! On my pda so searching tricky but if you search for Hayabusa controls my thread with the wiring diagrams and photos should come up. LOVE the choke and the look, as well as the ability to shut off the headlights.
Old Jan 27, 2010 | 03:53 AM
Erik S.'s Avatar
Originally Posted by 102dals
Erik,
No it doesn't plug right in like I hoped. Somewhere, recently, Inderocker did the same thing. What was needed was, pulling the turn signal switch out and replacing it with the SH switch, then the plug matched. That left you with a black/red wire that needs to be run to the corresponding wire on the Right Hand Switch on the SH, it's the headlight cutout circuit. Then the Firestorm left hand switch works.
cliby
Apr 26, 2008 05:32 PM
Besucher98
Jun 19, 2007 06:37 PM
Speed_Demon
Jan 21, 2007 09:47 PM
iscoot
Nov 7, 2006 11:45 AM
Hawkrider
Aug 3, 2006 11:33 PM
