Front turn sigs
Old Aug 13, 2008 | 07:13 AM
lowell's Avatar
Simi Valley, CA
lowell is on a distinguished road
Front turn sigs
Anyone try these or have a good suggestion:
I tried the Lockhart BULB markers but too much heat is melting the plastic and adhesive.
http://www.cyclegear.com/spgm.cfm?item=MRX_LFH1
Old Aug 13, 2008 | 09:13 AM
FTMS's Avatar
I have a set of those. They won't just bolt up and work. You would need to make a block off plate for the hole in the fairing. I scrapped the idea and installed them in the back as extras to go with my intergrated tail light.
Old Aug 13, 2008 | 10:55 AM
lowell's Avatar
Simi Valley, CA
OK, so the question is what SIGS will work on the curved fairing and where did you get the intergrated Rear tail for the hawk.
Old Aug 13, 2008 | 11:59 AM
FTMS's Avatar
Tailight is a Clear Altervative.
It is not that the cowl is curved is the problem, the hole for the OEM is larger than the whole light assembly. It fits inside the hole perfect, not around the hole.
Old Aug 13, 2008 | 01:30 PM
Hotbrakes's Avatar
Those are designed for F4i's and other CBR's that don't leave a gaping hole when the stockers are removed. I just got a similar set for the RC and I'm sending them back because it will be nearly impossible to install them and make them look pretty. You would have to remove the fairing to screw them into the plates that you make.
I have Lockhart Phillips LED's on the 'Hawk that are triangular shaped and completely cover the hole. They look good and are bright. I'll probably get another set for the RC as well.
Old Aug 13, 2008 | 03:38 PM
lowell's Avatar
Simi Valley, CA
The Turn Six LED? ?
Old Aug 16, 2008 | 06:51 AM
fishwater's Avatar
fishwater is on a distinguished road
The Turn Six LED? ?
Yep I have a set front & rear. The cover the hole if you position them properly & look pretty good IMO.
GlockPointer
May 4, 2013 09:27 PM
GlockPointer
Nov 7, 2011 08:48 PM
johnclopp85
May 13, 2009 07:20 AM
thegreep
Jul 31, 2005 07:22 PM
