front turn sigs
Old Nov 7, 2011 | 07:23 PM
GlockPointer's Avatar
Connie Demico does toad?
front turn sigs
Do I have to run a three wire front sig? I wired up some some two-wires and lost the tach and dash lights and nuetral light. Turn sigs work great tho.
Old Nov 7, 2011 | 07:29 PM
Sounds kind of like you blew a fuse? Check your fuses... is it possible that you short somewhere when wiring up the lights? Maybe the third wire is touching metal somewhere?
I'm running with two wire turn signals so that shouldn't be it...
Old Nov 7, 2011 | 07:43 PM
I see the main fuse but no others. Unfortunately I don't have any manuals yet.
Old Nov 7, 2011 | 07:55 PM
There's a whole fuse box in the left side of your tail (when looking forward). It looks like #11 in this pic:
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
Old Nov 7, 2011 | 08:48 PM
Thanks, it is under the seat right behind the tank. It's so small I thought it was a relay.
Well that did it for now, one 10a fuse out. I saw a 20a in place of a 10a and replaced it. I had figured if I disconnect 6 wires and only reconnect 4, then have probs, must be the wires.
No probs after warm up either.
GlockPointer
May 4, 2013 09:27 PM
johnclopp85
May 13, 2009 07:20 AM
lowell
Aug 16, 2008 06:51 AM
thegreep
Jul 31, 2005 07:22 PM
