Cracked Headlight Reflector - Why? Help!
Old Apr 9, 2015 | 07:13 PM
thedeatons's Avatar
So I recently found that my headlight reflector is cracked from the leading edge all the way to the center hole where the bulb is. I have no idea why this happened, and I'm trying to figure out the reason. As most of you know I took my bike nearly completely apart this winter to powder coat the frame. It is now all back together, and this crack appears to have occurred after reassembly.
I've been thinking about it, and I'm wondering if I have the faring brackets on backwards, causing a lot of stress on the headlight. What I mean is, I'm wondering if the brackets are pulling the faring back into the headlight mounting bracket really hard, and causing more shock than the factory intended.
If anyone has any insight as to why this happened, I would greatly appreciate it.
James
Old Apr 9, 2015 | 07:14 PM
thedeatons's Avatar
Pic 2
thedeatons's Avatar
Pic 3
Old Apr 9, 2015 | 07:15 PM
thedeatons's Avatar
Pic 4
Old Apr 9, 2015 | 07:16 PM
thedeatons's Avatar
Pic 5
Old Apr 10, 2015 | 11:27 AM
matt365's Avatar
this is what mine looks like.
Old Apr 10, 2015 | 11:44 AM
Matt365, you have a completely different bracket than what James and I have. That came stock?
Old Apr 10, 2015 | 01:32 PM
NZSpokes's Avatar
To many wheelies.
Old Apr 10, 2015 | 01:49 PM
CrankenFine's Avatar
Honda changed the design in later years.
Old Apr 10, 2015 | 06:01 PM
thedeatons's Avatar
Really? I have a 2001. Wonder when they changed it?
I can't believe wheelies caused this... Simply because I refuse to stop doing wheelies.
I only do power wheelies, and let the front end down gently. Fork seals are fine, which is further proof that i'm somewhat gentle.
Any ideas?
James
Old Apr 10, 2015 | 07:40 PM
matt365's Avatar
From the first picture, it looks like the bulb is right on the reflector. Should it not be recessed into the black plastic backing behind the reflector?
Just looks like its in too far to me.
Could be the retaining spring is putting pressure directly on the reflector.
Old Apr 11, 2015 | 12:42 PM
thedeatons's Avatar
Tell me more about this idea matt... Where should my bulb be?
Also, does it appear my brackets are mounted properly?
Old Apr 12, 2015 | 06:32 AM
Did you see bbancsov has a headlight for sale in classifieds?
Old Apr 12, 2015 | 11:15 AM
thedeatons's Avatar
Yep... My problem isnt finding a headlight... Its paying for said headlight
I'm hoping it lasts through the season
James
Old Apr 12, 2015 | 01:21 PM
thedeatons's Avatar
Matt... What did you mean about the bulb being pushed in too far? I didn't even realize that was possible!
James
Old Apr 17, 2015 | 06:16 PM
1971allchaos's Avatar
James
Let you and I trade Headlight assemblies.... I have a good headlight assembly.
And I could use your's to MOD to a HID headlight...
Old Apr 17, 2015 | 06:30 PM
thedeatons's Avatar
Seriously!????!!?! PM ME!!
James
Old Apr 17, 2015 | 07:38 PM
Wow! Chaos, you rock man!
Old Apr 18, 2015 | 08:56 PM
PLEASE, Don't attempt to embarrass me......
thedeatons
Mar 30, 2015 07:16 PM
spladle160
Nov 16, 2010 07:05 AM
johnnyhonda
Apr 2, 2007 09:15 PM
cb21983
Mar 19, 2007 02:33 PM
moisesdtp
Jun 8, 2006 09:39 AM
