Cheap cyclops light mod
Old Sep 20, 2011 | 08:13 PM
dehning's Avatar
dehning is on a distinguished road
Smile Cheap cyclops light mod
I'm always looking for cheap but good solutions when working on my bike projects and I thought you guys might appreciate this one:
I purchased this little LED array off ebay for $2.99 (Free shipping):
It comes with a couple of adapters one of which fits the VTR's 'cyclops' eye receptacle. It also comes with double sided tape and will attach perfectly on the front edge of the reflector allowing you to tuck the extra cable behind it.
It's quite bright too and does not touch the lens:
Not bad for $3
Old Sep 20, 2011 | 08:41 PM
BigSquirmy's Avatar
BigSquirmy is on a distinguished road
nice!
Old Sep 20, 2011 | 08:42 PM
That is very rightous. I got the superbrightleds.com bulb but it doesnt look that cool & wasnt $3! Nice..Can you post a link?
Old Sep 21, 2011 | 05:27 AM
dehning's Avatar
Cool
Try this link.
I just got the new 3W LED lamps from them for my CBR1100xx and I like them, they are not as bright as the 3W luxeon based bulbs but still plenty bright.
Old Sep 22, 2011 | 05:07 AM
nekkid's Avatar
This was too good to pass up. I just sent 3 dollars to China; that should help with the trade imbalance.
Old Sep 25, 2011 | 07:50 PM
dehning's Avatar
Originally Posted by anna1985beatufy
really good price . but just $3.00,can free shipping if another country ?
i will chose all parts from a good shop once time ,so that they can free shipping to me .
Old Sep 26, 2011 | 04:10 AM
CrankenFine's Avatar
Ditto.
Old Oct 5, 2011 | 08:32 AM
Cyfac0183's Avatar
Cyfac0183 is on a distinguished road
I had to do this as well- and it is SWEET!- in less than 5 minutes this thing plugged in and was doing it's lighting thing. very pleased- and honestly for $3 it doesn't matter if it burns out in 1 month- alteast i had a month of awesomeness- and that is worth it to me.
Old Oct 5, 2011 | 12:20 PM
Does the array put out much heat and how many amps does it draw (presumably much less than the OE bulb)?
Think I'll give it a try too.
Old Oct 5, 2011 | 01:03 PM
dehning's Avatar
Thumbs up
I think those LEDs draw 120 mW each which translates to 1.44W, I don't feel any heat off mine.
Old Oct 5, 2011 | 06:43 PM
Mine arrived today so installed it in a couple minutes when I got home from work. Can't believe how bright that little bugger is. Cheap thrills.
Old Oct 7, 2011 | 06:00 AM
wolfgun's Avatar
wolfgun is on a distinguished road
I'm thinking it's an internet language translator doing its' usual interesting job.
Old Oct 7, 2011 | 06:07 AM
dehning's Avatar
It was a little overcast this morning when I left for work on my SH, I'm actually quite surprised how noticeable the little light is
Old Oct 7, 2011 | 01:35 PM
Now I want to put LED replacements in all my turnsignals and tail light. I wonder if too low a wattage defeats the blinker function?
Old Oct 7, 2011 | 04:09 PM
dehning's Avatar
If by 'defeat' you mean that it makes them blink quickly then yes it does. However I have found that regular automotive electronic flasher units can be used on our bikes to fix this problem. A few $ at Autozone.
Old Oct 17, 2011 | 07:57 PM
j shizzy wizzy's Avatar
mildly retarded
Thanks man! I installed it with a little hot glue and a little trimming, its great.
Old Oct 18, 2011 | 09:44 AM
[QUOTE=dehning;315770]If by 'defeat' you mean that it makes them blink quickly then yes it does. However I have found that regular automotive electronic flasher units can be used on our bikes to fix this problem. A few $ at Autozone.[/QUOTE
Thanks for answering my question!
Apologies for my
Old Nov 24, 2011 | 02:22 PM
davidka's Avatar
What is the point of the "cyclops" light on this bike? Does this mod add usable light to see by? Never been happy with the headlight though a decent quality bulb and careful re-aiming has helped a little.
Old Nov 24, 2011 | 07:26 PM
You need the eastern beaver headlight relay direct wire hookup. It runs power through monster cables directly to the headlight & controls it with relays. Increases voltage and brightness by 35-45%. HUGE improvement. Motorcycle H4 Relay Kits, cheap Worldwide Shipping
Old Nov 24, 2011 | 08:33 PM
thetophatflash's Avatar
+1 installed a kit from Eastern Beaver. Headlight never flickers down. Worth the bucks and it came in about 10 days. Install was easy.
Old Dec 25, 2011 | 02:43 AM
salmanilla2000's Avatar
Which relay kit? I'm interested in trying this out.
1) H4 Single Headlight
2) H4 Single with Driving Lights Lead
3) H4 Heavy Duty Single Headlight Relay with Ceramic H4 Socket
Old Dec 25, 2011 | 08:37 AM
The H4 single headlight.
Old Dec 25, 2011 | 11:48 AM
dehning's Avatar
Cool
Sheesh, that relay kit is $55! For $50 you could get an H4 HID High/Lowbeam kit from DDM tuning that will give you drastically better light output. (I have them in my CBR1100xx & my VFR800)
...and that's a dual headlight kit intended for a car so you will end up with a second one you could sell to a buddy and split the price in half!
Old Dec 31, 2011 | 06:45 PM
What was the turn around time from the purchase on EBay to delivery?
Old Dec 31, 2011 | 06:53 PM
Been over and over on this forum, but while those bulbs technically work in stock housing, the reflectors are not designed for them. Light ouput is scattered, may cause interference with oncoming traffic and in general is less safe.
Someone mentioned that they make H4 HID bulbs now where the filament burns in the same place as stock, but I haven't seen that confirmed.
You do get brighter light, it's just less controlled. IMO a relay is actually better light unless you get the HID kit with projectors (which are designed for the way that the HID bulb burns, and so the light is controlled).
Old Dec 31, 2011 | 07:25 PM
Not as much as you think. I have the DDM hi/low kit and it's not as bright as I would like it. I was just about to post a question if I can incorporate the Eastern Beaver relay kit with the DDM hi/low kit. I know nothing about electrical engineering and most people on this forum are outright geniuses. So hopefully someone knows the answer.
Old Dec 31, 2011 | 09:38 PM
HawkRider98's Avatar
I purchased one and it was on my doorstep within 10 days of payment.
Old Dec 31, 2011 | 10:00 PM
So I am interested in the HID kit now. I have eastern beaver relays but maybe will install the hids in my other vtr and compare? Eventually.
Old Jan 1, 2012 | 12:20 AM
GlockPointer's Avatar
Connie Demico does toad?
Just bought 4 of those led "festoon" lights. I haven't festooned nearly enough lately. Ran me 10.76$
Old Jan 1, 2012 | 07:20 AM
dehning's Avatar
Cool
I'm surprised that people have had problems with HID lamps in the SH reflector. The H4 standard not only defines what the base looks like, but also where the source of the light should be located. As I said, I have them in my Blackbird, my VFR800, my Hayabusa and more recently, in my wife's Civic and they work great. I did make some minor aiming adjustments on some of them but that was all.
On the relays; I don't think you need a relay with the HID kit, they actually draw less current once they are lit. That being said,I actually use $15 DEI 528T Pulse Timers on all my installs so that the HIDs only come on after the bike is running saving on startup cycles on the transformer. The pulse timer actually pulls its main power directly from the battery and passes it through an internal relay so I guess it's technically performing the same function.
