Black rear brake line clips - ???
Hey guys... I can't stand my white rear brake line clips, especially now with the black swingarm.
I know I could dye mine, or paint them... But I would rather have some black molded Honda parts...
Anyone know of a part number that swaps over from another bike?
Thanks!
James
Thanks!
James
James,
This does not directly address your question, but what about taking your stock clips and using a fine wire as a hold, dip them in the black liquid plastic or "Dip It"? A couple of coats should do? Just a thought.
http://www.usplastic.com/catalog/ite...FRNp7AodnXgAow
Hondas that have a black swing arm..
2003 CRB600F4.. but the clamps mount from the side.
2007 CBR1000R looks like it might work though
CLAMP, RR.
43469-MEL-000
CLAMP, RR.
43469-MEL-000
And black
Which i thought was the point of this exercise lol
Point is...... go walk around a bunch of Honda's , find the ones with black swing arms, that route the brake line on top, and then order two clamps...
Or Plastic Dip the ones you have
Those may work i spose. They just an olive oxide zinc plated steel.
I dunno why they use those instead of plastic.
I want black, but i was hoping for the same look as original, which is why i mentioned a molded part, which refers to plastic
I'm not putting any band clamps from ace hardware on my sportbike, sorry... If it were a mil-spec equipment rack that would be different...
James
James
Sport-touring bike.
You could color all the things you want with a black permanent marker while they're on the bike. Saves a lot of time.
Or make one out of black twist ties and just be careful when you're bolting it down. Then it's metal and you don't have to worry about inferior ace hardware plastic failing.
Or use some black epoxy for a clean efficient no fastener approach!
I hold together my bike with yellow duct tape and if that's good enough for me it's damn well good enough for all you prissy pants types who are worried about bogus things like "attention to detail" and "safety"
James
James
Oh, and molded is a process, not specific to just plastic.... So if'n you wanted plastic.. perhaps say that.
But umm plastic.. ok... well there is
Acetal
Acrylic
HDPE
Nylon
Nylon Glass Filled
Nylon Nylatron GSM
Polycarbonate
Polyetheretherketone
Polyethylene Terephthalate
PTFE
Torlon
UHMW
Ok I get it you want an OEM look, but in black.... Do you have any bike wrecking yards near?
It's actually metal retainer with a rubber grommet inside, much fancier than the stock plastic clips that hold the rubber against a piece of metal and the sharp plastic edges of the stock retainer.
Also just throwing this out there..... If you wanted the "stock look" you should probably get rid of the black swingarm with the 900RR brace on it, neither of those came on the SuperHawk.....
Paint the things black and call it a day. It's not like it's a part that gets a whole lot of abuse. I'm very **** about things to. Don't like to do things the "cheap" or "easy" way. I want it done proper and not looking thrown together. ESPECIALLY with my bike. But it's to tiny of a part to matter. If it was something that got touched a lot then id say find a black clip. But paint it and it will be black for years
Pro Taper Universal Brake Line Guide Kit - Motorcycle Superstore
Pro taper cable guide it looks like.
I just bought the $3 pack of Ace 1/2" cable clamps just to spite all y'all and they work money. Couldn't take a picture because my phone is being a stubborn ***** but the are gen-u-ine Chinese plastic and hold that cable like an overly attached girlfriend in heat.
Seriously, though, they work pretty well. And look pretty nice. But the factory "don't twist me" location hole is open so that has to be dealt with. I'll get a pic this weekend.
rogeratdserve
Mar 19, 2013 08:25 PM
