View Poll Results: vtroth feb
YoshSuperHawk
14.81%
hawxter996
25.93%
thetophatflash
7.41%
kenmoore
25.93%
sailorjerry
3.70%
jscobey
22.22%
Voters: 27. You may not vote on this poll
VTROTM February 2014
Old Jan 30, 2014 | 09:00 PM
lloydievtr's Avatar
road racer v2 power
Thumbs up VTROTM February 2014
we have two winners this month well done guys .
hawxter996
kenmoore
Old Jan 31, 2014 | 09:55 AM
jscobey's Avatar
where do we subit nominations?
Old Jan 31, 2014 | 12:57 PM
lloydievtr's Avatar
road racer v2 power
If you want to enter pop the required info in the reply box :-)
Old Feb 7, 2014 | 12:21 PM
YoshSuperHawk's Avatar
2003 VTR1000F Candy Tahitian Blue Metallic. Waited three years for this color and glad I got it new off the showroom floor.
Mods-
Yoshimura RS3 Stainless exhaust with custom headers
Pyramid Carbon Fiber rear hugger
Superbike Store Double Bubble windscreen
Scotts top mount rotary damper
Rizoma sport grips
Pro Tek preload adjusters
Galfer Wave rotors (front and rear)
Galfer carbon pads
Galfer stainless Clutch and Brake lines
DID 530VX Gold Chain
Speedo Healer
Vortex -1 front sprocket and stock size rear cat5 Blue sprocket
Custom undertail made by Marcos of Rumble Import
Power Bronze ABS fairing lower
Old Feb 7, 2014 | 04:07 PM
thetophatflash's Avatar
My Baby
Greg Salwitz
1999 VTR
Yellow
Modifications: Dynajet Stage 1; TPS set to 500 ohms; FP 4 degree advance; FP Evostar and detent upgrade; Flo Commander; Trucinduc CCTs; Race Tech gold valves; HyperPro springs front and rear; stainless steel lines; EBC pads; Dunlop Q2’s; LP LED signals and flasher; Eastern Beaver headlight relay; LP smoke screen; Sargent seat; ASV shorty levers; PAIR removal; chin fairing, radiator grills, chain guard, rear fender and plate light ***’y painted Ducati red and Ducati Midnight black; Magical Racing mirror inserts; Vortex rear sprocket; 3rd eye replaced with GoPro mount.
Attached Thumbnails VTROTM February 2014-hpim1428.jpg   VTROTM February 2014-hpim1431.jpg   VTROTM February 2014-hpim1420.jpg
Old Feb 11, 2014 | 03:27 AM
All Present And Correct
Two years on the Storm lives.
When I got it the thing was stock standard and a little worse for wear, but the speedo was good at 9,000Klms.
A blank canvass so to speak. having owned some early ducatis I knew this thing had potential!
Here are 3 pics and you will have to look hard to see the mods.
That's the whole idea with my storm, subtle!
The list is long, too long to post, but not as long as some on here.
Go on, admit it blokes you've got the disease and you just can't stop tinkering.
That is what is so engaging about these bikes, No matter what you do, no matter how big or small, when you ride the bike you can sense the change.I did the Airfilter mod the other day and when I rode the bike there was a change in the power delivery and the engine was smoother. When I did the lightened Flywheel,the 4 Degree Ignition Advancer, Electric water pump and removed the anti rattle gear on the primary drive as well as the water pump drive gear and chain(All of this was done in an effort to reduce the reciprocal mass of the engine and make the engine spin up quicker to get the motor into the meaty part of the torque quicker- It worked!) the motor developed a vibration in the 3500- 4000 Rpm range. Now with the air filter mod this has almost gone.
I can assure you that the suspension is sorted, carbs done, and the braced swinger makes a world of difference.
I hope this is right!
Cheers from OZ!
Old Feb 11, 2014 | 05:58 AM
sailorjerry's Avatar
Genmar bar risers
DMr reworked forks
DMr F4 shock
Danmoto Rear sets
K&N air filter
Dynojet kit
FZ1 mirror mod
Sargent seat
Jardine RTone
Old Feb 11, 2014 | 06:03 AM
Jerry, you're much shorter than I pictured you.
Kenmoore, what windscreen is that and how's the fit and finish?
Old Feb 11, 2014 | 06:56 AM
****, I forgot when I was listing my mods to put in the Jockey Shifter. You know since my tiny legs cant reach the shifter..
Old Feb 11, 2014 | 10:03 AM
jscobey's Avatar
White '98 Canadian spec Firestorm. Full Hindle exhaust system with 20" semi high mount mufflers. RC51 SP1 forks, triples, calipers, rotors, and fender. RC51 SP2 5 spoke front wheel. Ohlins HO-701 3 way adjustable Rear Shock. All ***** steering bearings. Stage 3 Jet Kit. nissin master cylinder (my radial magura MC cracked but working on fixing it) Flush mount front turn signals. Integrated LED tail light. electronic flasher. Fender Eliminator. Dan-Moto 3 way Adjustable Clip ons and danmoto adjustable Rearsets. Sharkskinz Lower (cut away spot below header because it scraped on hard right hand turns). Carbon Fiber rear hugger. T-Rex sliders. Bar end mirrors. ReplayXD camera mounts. Repsol clutch and brake reservior socks. custom Mustache swingarm ;]
Old Feb 14, 2014 | 12:33 PM
lloydievtr's Avatar
road racer v2 power
poll now open
Old Feb 14, 2014 | 01:12 PM
hawxter996's Avatar
ole dirty bastard
i voted kenmoore
Old Feb 16, 2014 | 02:45 AM
Thanks Hawkster.
To get my bike to this stage there have been many mods, some big some small but most brought about by forums such as this.
First up was the cans followed by rear shock sim, then there was the Allen Screws everywhere that they could go.
Then the back shock was serviced and I did the fork mods when I changed the oil.
Yes, then it actually handled although it was stressed when pushed hard.
Then I went on a big trip to Europe that seemed to last a long time(4.5 Months)
I arrived back in Oz then took a job 2400 Klms away from home that was 3 weeks in 5 days out so I shipped the Storm up and then the games began.
J.E pistons , decked head , removed all water pump gears and fitted an Electric Pump(This can be seen if you look hard at the pics) 4 degree advancer, removed anti rattle gear and fitted a lightened flywheel. All this was done in an effort to get the motor to spin up quicker to access the torque quicker, and guess what it worked.(It was Dyno jetted as well)
Now that I was going quicker I needed to stop quicker so I fitted braided lines and CBR600F4i calipers.
****! It stopped quicker so I needed a fork brace so Mr Coerce came through and the front forks stopped flexing and now the **** end felt shithouse so I made a braced swinger and fitted that along with some Dan-rear-sets
Now all is well and there have been many other mods done that I haven't mentioned.
The one thing that I love most about these bikes is that no matter what you do to these bikes, no matter how big or small they respond and you can feel the change.
I'm sure that there is still much to be done, but for now I see a bike that is streets ahead of what it was when I first got it.
A neglected asthmatic piece of ****, that had potential.
This is bike no,42 and yes there is another one on the way but he Storm stays.
I would like to see a few more bikes in this, so come on guys take some pics and enter.
I might see something that I will want to do.
Knew I shouldn't of had that J.D single barrel night cap.
Cheers!
Old Feb 16, 2014 | 08:29 PM
jscobey's Avatar
hawxter996, your bike is something else man. basically a custom "Frankenstein" bike. i hate to say that cuz it sounds like its a bad thing but really your taking the best bits and pieces from all kinds of bikes and aftermarkets, and building it the way you want. i love it man. bravo. are you gonna keep it fairingless? it looks amazing. love the whole tail/exhaust/swingarm. one mean machine.
Old Feb 19, 2014 | 12:03 PM
Tebs's Avatar
Tebs is on a distinguished road
All are very nice bikes but hawxter996 got my vote. Sweet ride man!
Old Feb 19, 2014 | 08:04 PM
this is the fairing I want to run
Yep, seen that before, love it, I wouldn't mind the rest of the bike with all the components ;-)
Old Feb 20, 2014 | 03:16 AM
That's a bad *** bike.
I would love to give it a fang over my favourite bit of mountain road, but I would have to be in the right frame of mine to enjoy it.
One of those days where you and the bike connect!
Nice Bike eh?
Old Feb 20, 2014 | 09:42 AM
Still comming in with the goose egg?! Come on guys cant a brother get a single vote?
Old Feb 20, 2014 | 04:28 PM
matt365's Avatar
I went for Kenmoore's bike. Hawkster996's build has potential, but its still a "build", and not ride-able. I'll definitely vote it when its a running complete bike, but its currently a paperweight.
Old Feb 28, 2014 | 06:45 PM
hawxter996's Avatar
ole dirty bastard
who is spreading the rumor my bike isn't running?
oh you meant that one!.....lol!
Attached Thumbnails VTROTM February 2014-122_1010_05_o-2011_kawasaki_ninja_1000-.jpg
Old Mar 1, 2014 | 12:21 AM
Thanks to all who voted.
Shame there wasn't more bikes.
My New Aprillia Tuono V4 will be here in May, but the Storm stays.
Old Mar 1, 2014 | 10:57 AM
Congrats Kenmoore! I didn't even think that there might be a tie, but, well, there ya go.
Old Mar 1, 2014 | 10:59 AM
hawxter996's Avatar
ole dirty bastard
I wish to say thanks to those who voted.
But since I think there should be a clear winner.
I give one of my votes to Kenmoore.
After all as was said....his is a runner.
Old Mar 1, 2014 | 11:54 AM
But, BUT, VTROTM was for all bikes. Running or a project. Hawxter, you were soooo close. It actually took me like 15 minutes to choose between you and Kenmoore.
Old Mar 1, 2014 | 12:39 PM
hawxter996's Avatar
ole dirty bastard
thanks crux.
but to tie with a non runner has to sting a lil.
runner should break a tie.
Old Mar 2, 2014 | 12:03 AM
Not at all, I voted for yours running or not.
There is much to be admired and to be honest I thought you would win.
Well there ya go!!
Like I said before shame there wasn't a few more bikes entered.
Old Sep 11, 2014 | 04:59 AM
Well 7 months have gone by and the Hawk(Storm where I come from) has undergone a few changes.
I have done a lot of little things to the bike from an appearance point of view and think that it looks heaps better then it did before.
There a few bikes in the mix here but the Hawk, nay Storm is by far and away the most engaging.
Sometimes I hate the bike because it stops me from riding the others so now it's time to empty the Man Cave but the Hawk, nay Storm is staying.
Definitely be back next year and who knows what the bike looks like by then..
Hawkter996 where are you at with yours?
Here's mine now as it stands.
Lotsa changes!
I think it looks better!
What about you?
Catchya!!!
Old Sep 11, 2014 | 06:02 AM
You are getting rid of the Aprilia?
Old Sep 11, 2014 | 01:56 PM
Sadly yes.
I just don't have the time and have been made a good offer.
Some bikes are just steel and rubber to me.
I can use the $$$$ at the moment.
It will be going to a good home and I will be looking after it anyway so it's not so bad.
Goes at the end of the month but it will still visit the Man Cave from time to time.
Nice bike but the Storm does everything that I want and in my opinion is a better all round bike for the conditions here.
Have to admit that I will miss the rumble!
I have a couple of projects that need financing.
There is no way the Storm is going as I have invested too much time and $$$ into her!
The Aprillia has been like a couple of girlfriends I have had in so far as they had all the right bits in all the right places but just didn't do it for me.
Would love to be able to afford a 2006/7 RSV1000R or KTM RC8!
If that was to happen in the near future I reckon that the missus might alleviate me of a couple of dangly bits!!!!!!!!!
lloydievtr
Aug 1, 2014 02:38 AM
lloydievtr
Jun 12, 2014 08:25 AM
lloydievtr
May 1, 2014 08:16 AM
lloydievtr
Apr 1, 2014 05:19 PM
lloydievtr
Mar 3, 2013 07:54 AM
