View Poll Results: VTRoTM
7moore7
37
56.06%
Racer187x
3.03%
Thumper
16.67%
inderocker
19.70%
YoshSuperHawk
1.52%
SloBlue
1.52%
Travelinguy1960
1.52%
Voters: 66. You may not vote on this poll
VTR of the Month July 2011
Old Jul 1, 2011 | 09:02 PM
VTR of the Month July 2011 7moore7
Congratulations to 7moore7 for winning the June VTROTM!
Originally Posted by 7moore7
A BIG thanks to everybody who participated in June's VTROTM, If you did not win, be sure to get your nomination in again this month for your chance at SHF fame and glory!
Old Jul 3, 2011 | 07:30 PM
So nobody up for it this month??
Old Jul 3, 2011 | 07:48 PM
I'm of course in again... may be updating the pics if I replace the bar end mirrors. That was obviously the major downfall to last month... had nothing to do with mikstr's masterpiece ...
7moore7's naked VTR,
1998 29k miles
Suspension:
2000 CBR 929RR front brakes, calipers, rotors, wheel
Rear raised 8 mm
Ohlins rear shock
Body Work:
Hardened tank lines
Windscreen from VTR front fender
Carbon fiber rear hugger and front fender
Bar end mirrors
Custom vinyl seat covering
Cooling system:
Undertail Radiator (pusher and puller fan, wired to turn on at 90 degrees C)
CBR F4i gauge temp sender
Custom coolant overflow bottle
Engine Ice Coolant
Electrical:
CBR F4i Gauges
HID projector headlamp
CBR 600RR stick coils
TPS ohms set to 499
R1 R/R
DeWalt 28v Lithium conversion to 14v battery
Rear LED integrated turn signals
Cosmetic:
Custom anthracite paint (High-end clearcoat used)
De-nubbed brake and clutch levers
Powdercoated frame, swingarm, wheels, rearsets, levers, clipons, gas cap ring, valve covers, passenger footrest supports, triples
Painted engine side covers
Everything Else:
APE CCT's
16/43 Sunstar gears
DID X-ring 530 gold chain
De PAIR'd
Muzzy carbon fiber slip ons
Wrapped and silicon coated exhaust headers
SS front brake and clutch lines
AllBalls wheel,steering, and swingarm bearings
Slow carb slide adjustment (HRC copy)
Billet Velocity Stacks (HPower of Australia copies)
T-Rex frame sliders
Old Jul 3, 2011 | 07:57 PM
fred's Avatar
Mid-level Member
fred
nice first entry!
Old Jul 4, 2011 | 06:24 AM
RWhisen's Avatar
Former Superchicken Owner
Good looking bike. I have followed the build from the initial "Oh S**t".
Old Jul 4, 2011 | 06:45 AM
This bike has come a long way! I knew very little about motorcycles in general, and it was basically built because of this forum. The advice and ideas around here allowed me to make a mechanically sound and functioning machine
https://www.superhawkforum.com/forum...rebuild-23868/
Old Jul 5, 2011 | 01:28 PM
Well come on guys, we need more than one bike here.....
I still have 3 months before I can enter again so it's up to you guys to step up.....
Old Jul 5, 2011 | 01:53 PM
Old Yeller's Avatar
You can't enter again until I win. that's gonna take a while.
Tormoz's Avatar
Tormoz is on a distinguished road
Nice! Hiding the radiators under the tail really helps your bike stand out among other naked Superhawks. Is that some sort of mesh material under the passenger seat area to help airflow to the radiator? Looks great!
Old Jul 5, 2011 | 02:01 PM
Yep, it's a mesh material- not a super free flowing one, but I can replace it if that becomes a problem. The single radiator/under tail setup has actually been working better than I expected here in Phoenix. I'm more limited by my tolerance of the heat than the bike. Haven't done any long high speed trips yet, which I think will be most taxing. I have to give credit where it's due, too- this is very similar to a setup that member Kai Ju created a few years ago, and he was very open in sharing his knowledge!
Old Jul 7, 2011 | 04:26 PM
racer187x's Avatar
racer187x is on a distinguished road
I was supposed to enter last month but got busy with work and hadn't taken the time to clean her up. I bought her a couple months ago as a daily rider and have fallen in love. It's a '98 with some miles on it, 45,000 but runs like a champ and was well maintained by the previous/first owner.
I kinda wish there was a "bone stock" class for me to enter! It is completely stock for now with the exception of the manual CCTs and the paintjob (Porsche red). It even had the noob reflectors on the stock rear end still. Waiting on forks (shock next) from JD as I'm way over these stock spring rates. If you can believe it, I can fit on this stock bike even at 6'8" tall but it is super uncomfortable as can be imagined. I've got parts ordered and on the way but probably won't be done before the end of the month.
Attached Thumbnails VTR of the Month July 2011-sh-pics-7.7.11-001.jpg   VTR of the Month July 2011-sh-pics-7.7.11-004.jpg   VTR of the Month July 2011-sh-pics-7.7.11-005.jpg
Old Jul 7, 2011 | 06:16 PM
superhen's Avatar
Not only is the 7moore7 bike the best looking SH I've ever seen, it's one of the best bikes I've ever seen, period! Wow is all I can say, I can really appreciate all the work that went into the build. Very nice job.
Old Jul 7, 2011 | 06:52 PM
Thumper's Avatar
Well i will post up my old girl. Still got her and she is in top notch condition. to many mods to list.
Mods / ETC:
-Corbin Seat
-LP signals
-Jardine High mount Exhaust with Wrapped headers
-Two Brothers SMOG block off plates with all smog stuff removed
-Rear Fender mod
-New Chain (DID o-ring) Sprockets are like new
-Signal Dynamics Head light modulator
-GSX/R 1000 Front 6 – pot front calipers
-GSX/R Radial Master Cylinder
-Steel braided Brake and clutch lines
-K&N Air Filter
-Factory Pro Ti Jet kit tuned perfect top to bottom rpm range
-Factory Pro Ignition Advance
-APE Manual Cam Chain Adjusters
-Remote Carb Sync lines ran for easy carburetor Sync
-Vesrah HH Pads
-RaceTech Gold Valves in Forks
-RaceTech fork springs for 190 lbs rider
-Custom Vinyl graphics
-SRC Fork Brace
-Stripped and polished wheels
-Mirror Extenders
-VFR Voltage Regulator
-Modulating Rear Brake Light
-Safety Wired for looks
-Rear passenger pegs and brackets removed
-Smoke Double Bubble windscreen
Old Jul 9, 2011 | 12:55 AM
Screw it, I'm in!
Mods so far...
-De-Burred & Polished Heads
-Yoshimura RS3 Titanium Slip On's
-Factory Pro Ignition Advancer
-Factory Pro "Ti" Jet Kit
-Factory Pro Evo Shift Star Kit
-'98 VTR Shifter Assembly
-K&N Air Filter
-TBR Pair Block Off Plates
-A.P.E. Manual Cam Chain Tensioner's
-F4i Front Brake Master Cylinder
-F4i Front Calipers
-Ohlins Steering Damper
-Race Tech Rebound & Gold Valves
-Gold Anodized Fork Caps (à la 2004 VTR)
-Pro Bolt Preload Adjusters
-Ohlins Rear Shock
-Michelin Pilot Road 2CT's
-D.I.D. X-Ring Gold 530ZVM2 Chain
-OEM Front & Supersprox Rear Sprockets 16/41
-Galfer Steel Braided Brake Lines
-Goodridge Steel Braided Clutch Line
-Throttlemiester Bar Ends
-Euro Pass Light Switch
-Helibars
-Zero Gravity Double Bubble Windscreen
-Sargent Seat
-Renthal Grips
-Trimmed Rear Fender
-Clear L.E.D. Rear Combination Light
-Clear Flush Mount L.E.D. Turn Signals
-YZFR6 Regulator Rectifier
-Galfer Wave Rotors
-Carrozzeria Vtrack Forged Aluminum Wheels
-All ***** Heavy-Duty Tapered Steering Head Bearings
-Scorpio SR-i600 Alarm
Old Jul 9, 2011 | 08:25 AM
YoshSuperHawk's Avatar
2003 VTR1000F Candy Blue Metallic. Waited three years for this color and glad I got it new off the showroom floor.
Mods-
Ported/Polished heads
Yoshimura RS3 Stainless exhaust with custom headers
Pyramid Carbon Fiber rear hugger
Superbike Store Double Bubble windscreen
Scotts top mount rotary damper
Rizoma sport grips
Pro Tek preload adjusters
Galfer Wave rotors (front and rear)
Galfer carbon pads
Galfer stainless Clutch and Brake lines
DID 530VX Gold Chain
Speedo Healer
Vortex -1 front sprocket and stock size rear cat5 Blue sprocket
Custom undertail made by Marcos of Rumble Import
Power Bronze ABS fairing lower
Old Jul 9, 2011 | 01:21 PM
oahu hawk's Avatar
geezer
Wow!...some very nice SuperHawks this month, no losers here...
Old Jul 9, 2011 | 02:08 PM
t-dogg's Avatar
Nice! We got some old timers here this month. Im really glad to see this is still going on as I used to look forward to it every month!
Old Jul 9, 2011 | 03:00 PM
kai ju's Avatar
The mesh does make a difference, I tried running mine closed off and the radiator didn't like it one bit. The fan never cycled off like it does with the mesh in place.
Thanks for the kudos, I appreciate it. Yours is now the fourth iteration of the the under seat radiator set up. Kinda cool that I started a trend with that.
I had my bike entered in VTROTM once or twice but never got it, my vote will have to go to you just for that, not to mention the excellent execution you achieved.
Old Jul 10, 2011 | 08:47 AM
Killemall's Avatar
Wow dude. That's probably one of the best naked SH I have ever seen. Really well done! My vote goes to you for this month.
Now I'm tempted again to tear mine completely apart and get everything powder coated. The difference in look is just amazing.
1998 29k miles
Suspension:
Rear raised 8 mm
Ohlins rear shock
Body Work:
Hardened tank lines
Bar end mirrors
Cooling system:
Engine Ice Coolant
Electrical:
CBR F4i Gauges
TPS ohms set to 499
R1 R/R
Cosmetic:
Everything Else:
APE CCT's
16/43 Sunstar gears
De PAIR'd
T-Rex frame sliders
Old Jul 10, 2011 | 10:05 AM
JPP's Avatar
JPP
I followed the rebuild thread with mild interest until I saw the Yellow valve covers. Then I was thinkin', now we got something! The bike is the first naked version I've liked. I'm slowly getting used to the "Alien" front fender cowl thing. If I wasn't such a Ridley Scott fan I probably wouldn't have noticed the similarity.
So far my favorite. Makes me think Honda should have made it like that.
Old Jul 10, 2011 | 05:39 PM
SloBlue's Avatar
SloBlue is on a distinguished road
I got in a very cool ride up to Estes Park, Co. this morning and took a pic on my phone of my bike. I'm pretty sure the mountains in the background are part of Rocky Mountain National Park. It looks like some pretty nice Super Hawks are posted up here, but I'll throw in mine.
[IMG][/IMG]
Old Jul 10, 2011 | 05:51 PM
I used to live in Loveland, and would really like to get back up there on a bike (I didn't ride back then)! Gorgeous photo!
To get a full sized image, upload the photo to a host site like photobucket, then copy and paste the IMG link in your text.
Old Jul 10, 2011 | 05:57 PM
I got a convex bar end mirror for it and took the cafe racer ones off and it's much cleaner now. Hopefully I can get some pics up before the 15th or 16th or whenever
Old Jul 14, 2011 | 12:35 PM
Time is running out....... nobody else willing to give it a shot???
Old Jul 14, 2011 | 01:50 PM
Travelinguy1960's Avatar
Sanely riding since 1975!
Travelinguy1960 is on a distinguished road
Vote for the Nube!
Never one to back down, I'm all in!
Here is my stock 1998 996 Super Hawk with 2 brothers lower fairing.
17,300 miles, daily driver, owned since new in 1998.
Never down, sees rain almost daily!
Vote for the Nube!
Thanks,
Gunny
Original owner
Year: 1998
Color; Milano Red
Miles: 17,300 . Daily Driver
Mods: Two Brothers Lower Fairing since new.
Home Town: Seattle, USA
Average Mean Temp: 59'
Attached Thumbnails VTR of the Month July 2011-my-996-superhawk.jpg   VTR of the Month July 2011-bike-me.jpg   VTR of the Month July 2011-vtr1000f-1.jpg
Old Jul 14, 2011 | 01:52 PM
P.S. Can someone tell me how to get my picture to be full size and not just a thumbnail?
I have the same question!
Great looking bike in Blue!
Good Luck,
Gunny
Old Jul 14, 2011 | 01:54 PM
Looking good, right on the line!
Old Jul 14, 2011 | 02:00 PM
The Grey is so good looking and your mods are worthy of much envy!
Amazingly Studly Super Hawk!
Old Jul 14, 2011 | 02:03 PM
Get's my vote!
Best looking naked Super Hawk I have ever seen!
Get's my vote!
Old Jul 14, 2011 | 02:10 PM
So Sexy!
Mods / ETC:
-Corbin Seat
-LP signals
-Rear Fender mod
-K&N Air Filter
-Vesrah HH Pads
-SRC Fork Brace
-Mirror Extenders
This is the sexiest Super Hawk I have seen so far.
Just amazing.
You must get so many compliments!
Good Luck!
Gunny
