Huh?
Old Apr 20, 2012 | 08:00 AM
Naked'98's Avatar
Naked'98 is on a distinguished road
Huh?
About time for some pics I'd say....
Old Apr 20, 2012 | 08:08 AM
I must confess that most naked VTRs leave me somewhat indifferent but you seem to have put the pieces togehter just right. Congrats on a nice job.
BTW, what subframe are you running?
Old Apr 20, 2012 | 08:48 AM
rz_racer_69's Avatar
Old and dangerous
Very nice looking. Radiator in the tail section?
I like the inspection sticker on the tail light.
Any cops see it yet and allow its location?
Old Apr 20, 2012 | 08:51 AM
thetophatflash's Avatar
Looks good! What part of WA are you in?
Old Apr 20, 2012 | 09:10 AM
Way way way nice, man! Damn that's a good looking naked.
Get a seat cowl for that sucka! And move the "nose" horn... that thing looks like a muppet
Props to the VFR tank, clean rad and large oil cooler...
How does she run?
Old Apr 20, 2012 | 09:21 AM
speedkelly@aol.com's Avatar
Really great job there man. Looks clean and simple. I bet its a blast to ride.
One day I would love to build a cafe racer out of a superhawk. Sort of a retro Egli Vicent, Ducati classic mish mash. Enjoy your ride.
Old Apr 20, 2012 | 09:38 AM
HRCA#1's Avatar
Question
I agree but this one is nicer than just about anything else I've seen. What radiator was used, VLX? What oil cooler? Any install pic's?
Old Apr 20, 2012 | 11:32 AM
RWhisen's Avatar
Former Superchicken Owner
Like Mikstr said, most nakeds are just "Meh" to me but yours looks very nice. I think the only thing I would work on would be how to clean up the oil hoses that go all over the place. One of the things that makes or breaks a naked to me is doing away with the clutter and with that one exception you have done a great job. How does it run with the two into one setup? Loud?
Old Apr 20, 2012 | 11:49 AM
kai ju's Avatar
That looks eerily familiar...........it's nice to see more undertail radiators, really cleans up the lines of the bike.
Nice job, let's see the fan set up.
Old Apr 20, 2012 | 04:21 PM
Naked'98's Avatar
mikstr- subframe is a chopped down stock unit.
Rz- sticker is actually a parking pass, no hassling from the cops yet...
tophatflash- mostly between Seattle and Bellingham.
7moore7- I'd like to run a cowl at some point, though I narrowed my tailsection so the stock unit would be too wide, wonder how it would look narrowed with a small ridge down the center?
As far as running, she runs pretty well, I followed the carb setup guide on this forum and it worked well for me. Good, even power throughout the rev range but I do still need to tweak my idle circuit as i get slight popping with the throttle fully closed below 3K RPM.
RWhisen- yes, actually the oil lines are temporary, I will be cleaning those and a few other small things up in the future
Kai Ju- It is fairly similar to your build. I actually saw some frustratingly small pictures (couldn't find full-size at the time) of your bike before i bought mine ~1 year ago, I believe it still had the factory tank? Your bike was the one that inspired me to do the undertail radiator and the venting. Believe it or not, i hadn't actually seen your build thread or detailed pictures of you bike until I dug it up today after reading your post. The two bikes do indeed have eerie similarities: Ninja oil cooler, CBR954 forks, undertail, venting, VFR800 tank, etc.
To all of you, thank you for the kind words. To be honest, I was a little apprehensive to post this up as most are not fans of 2 into 1 exhausts and naked Superhawks.
Details to follow but for now here is a few shots of the radiator installation:
Old Apr 20, 2012 | 04:41 PM
Very nice
Old Apr 20, 2012 | 04:52 PM
Naked'98's Avatar
Now for a little background and the details:
I got the bike almost a year ago now. When I picked her up she was in pretty sorry shape. The bike had been down twice in the past, once on either side, and the previous owner had torn a lot of parts off en route to a minimalist, naked fighter. She was sporting a bent pair of GSXR600 front forks (minus the rotors and master cylinder) No bars, no ignition switch, no gauges, no headlight, no fairing or fairing stay. The frame was covered with scratched black paint, the tank was included but had not been made to fit (no mounts or block-off). Factory airbox was included with a K&N but the velocity stacks had been chopped in an effort to mount pod filters. Rear cylinder head was off of the bike (apparently for porting?). Exhaust had been cut up as a start to the 2-1 setup. Tail fairing had been sectioned 2"? narrower. Lastly... all connectors for hand controls, gauges, etc had been cut off of the harness. I had a pretty big project on my hands.
Bike is not yet done (when are they ever) but close. Future plans include:
-2-1-2 high mount exhaust, I like the look and sound of the setup I built though am probably losing some power.
-clean up lines and wires further.
-I have an RC51 SP1 swingarm and CBR954RR rear wheel that will find their way onto the bike eventually.
-Racetech internals for the front shock and a new rear.
-Newer rear tail?
Along with who knows what else
Right now what I have done is:
-custom 2-1 exhaust (cut and pieced together factory parts) with viper silencer.
-Converted the CCT's to manual via the stainless carriage bolt method.
-VTX1800 radiator mounted in the subframe (converted to cross-flow and a filler neck added at the top)
-stock airbox, paper filter, stock velocity stacks. Bigger jets, lifthole block, shimmed needles.
-TPS reset.
-mounted coils to LH rear of the airbox.
-CBR929RR fork bodies and dampeners which I rebuilt and installed GSXR1000 springs into
-CBR954RR front wheel
-520 chain conversion (stock gearing though)
-Narrowed tail fairing
-VFR800 tank
-Hugger
-Integrated led tail
-GSXR600 front fender
-Re-mounted all electrical and shortened the entire harness accordingly.
-New mount for the factory-style cluster and wired on new connectors for everything.
-Headlights on relays w/ a diode bridging the two so low beam is one light and high beam is both.
-Grip heaters
-Vista-cruise throttle lock
-Bar end mirrors
-Stainless lines
-Ninja oil-cooler
Wow, what a mouthful, and i'm sure I missed a lot, I've got many, many hours into this build...
Thanks again.
Old Apr 20, 2012 | 04:57 PM
One thing you could look into to save some space is put some CBR stick coils in there...
Awesome narrower tail, I didn't even notice that first time around. And a line down the middle of the cowl would probably look sick.
Old Apr 20, 2012 | 05:01 PM
raylohne1's Avatar
raylohne1 is on a distinguished road
jesus...I never thought I'd like a naked...
I've seen the light Lord...
but I'll only do it if I get a chance to buy from someone like meanhawk...
wonder what he got for his bike?
great job...really...beautiful...
Old Apr 20, 2012 | 05:02 PM
raylohne1's Avatar
BTW...I agree about the horn...looks funny...
but other than that...
looks fantastic...
Old Apr 20, 2012 | 05:04 PM
raylohne1's Avatar
Oh...one other thing...where did you get that gorgeous rear hugger?
Old Apr 20, 2012 | 05:14 PM
raylohne1's Avatar
and...if this is a SQUID's bike...
then I'm spongebob squarepants diaper...
Old Apr 20, 2012 | 07:17 PM
NOT a fan of nakids but this bike is a real work of art.
I want more details on the tail rads...... Does the fan run all the time? Is it one rad or 2? What rads? Why a huge tank on a bike that doesnt want to go that far?
I want answers immediately.... Thanks
Old Apr 20, 2012 | 08:14 PM
oahu hawk's Avatar
geezer
Nice naked, dual headlight set up looks very cool...be sure and post up more pics as your project moves forward...
Old Apr 22, 2012 | 10:35 AM
Naked'98's Avatar
Single Rad from a VTX1800, single fan which infrequently turns on. If it becomes insufficient in the summer heat I will add a second. As for the tank...I like the lines and I also run er til she's dry then filler up for more...
Old Jul 24, 2012 | 10:19 PM
Naked'98's Avatar
Tweaked my tune a tad more and swapped to an FH020AA yamaha style regulator/rectifier. Other than that, just riding for now...
Old Jul 25, 2012 | 04:58 AM
Most are not overly excited about wrecked bikes the owners can not afford to fix being turned in to "Street fighters" which normally means no more then rip off the broken bits and bolt on random parts to get it back on the road.
YOUR build is about as far from that as it can be.
Nice work, and while the Street fighter look is not for me... Yours looks good.
Really only two things that look..."unfinished"
The horn placement.. and the oil filter, normally hidden by a cowl or faring.
The Horn... not sure tuck it up at the cost of loosing volume and reach..
The oil filter sticking out like a .. well never mind,, but sticking out....
I'd be tempted to make/buy a oil filter by pass plate that will work, and remote the filter to another location...
Or, machine the case to except AN fittings and remote the filter to a new location.
And as suggested, you have done well with cleaning up the front end area normally covered in plastic.. ditching the coils and going with COP would extend that work.
Over all nice work.. and.. if I built a Nekid SH, it would look like this one.
Old Oct 31, 2012 | 02:51 PM
Naked'98's Avatar
Not much progress, just riding. I did however find the factory chin and associated brackets while digging through my SH parts. Looks much better now. Might spend some time re-routing things this winter, for now I work on the car project...
Old Oct 31, 2012 | 06:22 PM
VtrInMtl's Avatar
VtrInMtl is on a distinguished road
And I just got that exact same hugger, so thanks for the pictures, now I know how it mounts.
Old Aug 17, 2013 | 12:50 PM
JKnight5's Avatar
JKnight5 is on a distinguished road
How did you mount the stock guages?
Old Aug 18, 2013 | 07:29 AM
twinman's Avatar
twinman is on a distinguished road
Awesome build!!
calitoz
Nov 28, 2006 07:48 AM
