SuperHawk Forum
-   Members Rides (https://www.superhawkforum.com/forums/members-rides-35/)
-   -   ‘04 Going Naked (https://www.superhawkforum.com/forums/members-rides-35/%9104-going-naked-36194/)
Squid 04-15-2024 08:23 PM
Originally Posted by Bald Eagle (Post 416525)
I am assuming the holes will be how the hot air from the radiator will be escaping.....?
Will the fan be attached to the radiator facing the holes.?
I see no issues with your glass work.....kind of clever to fiber glass the two pieces together.
you are correct. I do not have the fan. It was broken from the PO when he laid it down. Will have the fan mounted on top of the rad to pull up and push out thru the holes.
thank you, first time Messing with the stuff and I’m pretty happy with it. Not flawless but I’m no pro. I also cut out the overlap of the tail section where the cowl sit to prevent any area that would disrupt airflow.
https://cimg7.ibsrv.net/gimg/www.sup...3fb65f3400.jpg
https://cimg1.ibsrv.net/gimg/www.sup...63c9c78b38.jpg
Bald Eagle 04-25-2024 07:01 AM
I have an additional fan if you need one. It is stock style fan ..... I'll have to dig it up (find it), with the blades reversed so you are pulling the cool air out through, what was the wife's seating area....:D.
Not sure if you should upgrade to a more powerful unit though.....since you will be having to make your own brackets for the Radiator.
Squid 04-25-2024 11:58 AM
im not too sure on what I will be doing as far as a fan goes for now. If I need it I’ll it you up. I’m still trying to get it running right.
Squid 04-25-2024 12:02 PM
Carb tuning is now a priority. But after that all that is needed is todo is mount the brake light, turn signals on both ends, and make a rear brake stay for the underslung caliper.
https://cimg8.ibsrv.net/gimg/www.sup...db8c43caf.jpeg
https://cimg2.ibsrv.net/gimg/www.sup...06d5acedb.jpeg
https://cimg8.ibsrv.net/gimg/www.sup...1279983e6.jpeg
Squid 05-06-2024 12:20 PM
Rear brake mounting
Mocked up for now till I can find someone to weld in the front caliper mount stay.
https://cimg7.ibsrv.net/gimg/www.sup...4dae3d8ec.jpeg
https://cimg3.ibsrv.net/gimg/www.sup...9f09b671a.jpeg
https://cimg8.ibsrv.net/gimg/www.sup...0409c983a.jpeg
Tripleplay707 05-08-2024 08:13 AM
helluva ride!!!
can we get some vids????
Squid 05-08-2024 11:39 AM
Originally Posted by Tripleplay707 (Post 416593)
helluva ride!!!
I’ll do a walk around vid this weekend and a sound clip.
Squid 05-10-2024 05:52 PM
Walk around video
Here is it, 90% complete.
https://youtu.be/_dvRbg77LpE?feature=shared
Tripleplay707 05-11-2024 06:48 PM
Wow
Helluva ride...
Amazing build!:cheers:
I applaud you!!!
