timing front cams
Old Aug 11, 2009 | 05:17 PM
rnb's Avatar
rnb
rnb is on a distinguished road
timing front cams
The front chain jumped while I was turning the motor over to replace cct. How do I retime the cams? Any help would be appreciated. Thanks.
Old Aug 11, 2009 | 06:02 PM
killer5280's Avatar
Download the manual from this site and follow the instructions carefully. Go over it several times to make sure you understand it and have it right.
Old Aug 11, 2009 | 06:18 PM
gboezio's Avatar
Bring the engine to the FT mark on the compression stroke (no valves open) and align the two marks with the head surface.
To move the cams, remove the chain guard between the two cams, pull the slack and hook the chain on the sprocket one tooth further, the chain links will form a little triangle and move this extra half link around the sprocket, repeat as necessary until when you put tension back the cams are aligned like they should.
When done move the engine by hand two full turns or more to make sure you did not mess up and put the cam in a way that will destroy the engine when you fire it up.
Here's an example for the rear cylinder, but you need to use F-I for the intake cam and F-E for the exhaust cam.
Old Aug 12, 2009 | 09:42 AM
rnb's Avatar
rnb
Thanks so much for the help.
Old Aug 12, 2009 | 10:13 AM
RCVTR's Avatar
If the cams jumped, you removed the CCT while the valves were open. You will need to reference the front timing position from the rear cylinder.
The correct timing for the front cylinder is 450 degrees of crank angle after the rear cylinder (1 revolution + 90 degrees).
Remove the timing chain from the front cams, so you don't open the valves when the piston is near the top of the stroke. Locate the rear timing position, then rotate the crank 1-1/4 turns to the front timing mark, then install the timing chain, with the cams at the correct orientation.
Old Mar 8, 2010 | 07:47 AM
996HAWK's Avatar
996HAWK is on a distinguished road
did u get it i did the same thing LOL
Old Mar 8, 2010 | 08:57 AM
+1 any other method risks engine damage.
and the rear timing position is RT on the flywheel and the cam lobs pointing out with the timing marks as shown in gboezio post.
Old Mar 11, 2010 | 08:53 AM
996HAWK's Avatar
I unbolted camshaft and repositioned because my top and bottom on crank was off
laxcuz
Jul 23, 2015 11:42 AM
shawnlgerber
Feb 4, 2014 09:06 PM
Renderw
Aug 11, 2012 01:18 PM
cliby
Mar 1, 2007 09:55 AM
