Questions about front cylinder timing.
Old Jan 28, 2014 | 11:59 AM
shawnlgerber's Avatar
shawnlgerber is on a distinguished road
Hi all new to the forum, long story short I had my front CCT fail, pulled the head and found no damage to valves or piston, cam chain was slipping so bad it wouldn't engage the valves at all. As I'm putting the motor back together I'm wondering about the timing for the front cylinder. I have the flywheel at FT and am aligning the cams to the proper mark. My questions is since this is a 4 stroke had the piston is at TDC twice per cycle how do I know I am aligning to the correct one? I haven't touched my rear cylinder so I'm thinking I can use the position of those cam lobes to know when I am at the correct TDC. Thanks in advance!
Old Jan 28, 2014 | 01:34 PM
comedo's Avatar
Good question and you're right about using the rear cylinder to time the front cylinder. There's a copy of the shop manual in the Knowledge Base and an article there on CCT installation. There's another helpful article on www.vtr1000.org, the British VTR site. Read the manual and the articles and you'll have no difficulty sorting it out. You might consider installing manual CCT's while you're at it.
Old Jan 28, 2014 | 02:45 PM
Noted on the CCT defiantly lucked out on this one.
Old Jan 28, 2014 | 04:54 PM
RobertLever's Avatar
Welcome Shawn.
Please read the threads on manual Cam Chain Tensioners (CCTs).
Old Jan 28, 2014 | 08:01 PM
Originally Posted by RobertLever
Welcome Shawn.
So from what I can discern from the other thread is turn the flywheel until its at RT AND the cam lobes are upward and inward on the rear came, then turn 450 degrees counter clockwise to align with FT and align the cams to that correct??
Old Jan 29, 2014 | 11:07 AM
comedo's Avatar
Yes. See p. 8-21 in the Service Manual.
Old Jan 29, 2014 | 11:30 AM
Yes^^
Old Feb 4, 2014 | 09:06 PM
Got her all buttoned up guys thanks for the help!
Renderw
Aug 11, 2012 01:18 PM
aja
Dec 21, 2011 10:05 PM
Acecool
Aug 24, 2010 03:21 PM
rnb
Mar 11, 2010 08:53 AM
vmoto
Oct 4, 2006 12:51 PM
