Suspension Tech
Old Jun 15, 2005 | 05:12 PM
caffeineracer's Avatar
caffeineracer
Excellent! RC thanks for posting.
I've waiting to find an engineer to ask and question that came up when I did my valves.
Say you had a compression valve with four 1.5mm ports.
Then you were able to drill these ports out to 3.0mm.
I don't know engineering terms but wouldn't this change the hydraulic leverage on the shim stack?
Because the rebound piston would have to travel further to move the 3mm column of oil through the port than it would the 1.5mm column that's half the size.
So wouldn't the stack would open with less force at the wheel?
Sort of like different piston sizes in a brake system?
Thanks
~Jeffers
Old Jun 16, 2005 | 08:13 AM
penst8grad's Avatar
penst8grad
Very nice RC.
Reminded me of sitting Physics class again. I was worried you were going to go into derivitives for a second.
Haven't seen them since college.
residentg
Jul 25, 2010 08:04 AM
redman
Aug 25, 2007 09:02 AM
L8RGYZ
Apr 16, 2007 04:13 PM
hawkbill
Mar 13, 2007 06:08 PM
102dals
Nov 27, 2006 02:46 PM
