Shift kit??
Old Mar 1, 2010 | 12:25 PM
boxdogracing's Avatar
boxdogracing is on a distinguished road
Question Shift kit??
I have been looking at shift kits, Factory Pro offers two. One with the shift star, and one without. My search only found threads on the star kit, anyone know the difference once installed other than the $105 difference. Also should I have special tools lined up. I've read about people braking clutch baskets and/or bolts.
Old Mar 1, 2010 | 12:34 PM
I installed the detent arm kit (with spring), optin against the Shift Star. The bike shifts quite well but, in hindsight, I should have gone whole hog and gotten the Star too (as you`re already in there, so to speak). I have since ordered a Shift Star ($130 when ordred separately) and will have it put in with my rebuild at some point in the future. Take my experience for what it`s worth.....
Old Mar 3, 2010 | 04:27 AM
redmanmbz's Avatar
redmanmbz is on a distinguished road
If you use the correct tools, you won't have a problem damaging/breaking the clutch basket.
Old Mar 3, 2010 | 06:37 AM
Use the whole kit, the detent arm by itself made little difference IMHO. Very slick shifting with the whole kit installed.. Then add a DMr shifter shifter from and your all set.
Buy or make clutch basket tool.. doing without or using a screw driver, pry bar, ect ect.. will often result in a broken basket or hub.
Old Mar 3, 2010 | 06:45 AM
Originally Posted by TXSuperChicken
Use the whole kit, the detent arm by itself made little difference IMHO. Very slick shifting with the whole kit installed.. Then add a DMr shifter WITH NEEDLE BEARING and you're all set.
Fixed it for you
Old Mar 3, 2010 | 08:37 AM
Originally Posted by mikstr
Fixed it for you
You know that bearing is sitting on the bench mocking me at this very moment.. I'm in the shop right now working on another bike and getting ready to clear the lift to put the SH on and change some jets.... The bike shifts so well now.. the shifter MOD has not gotten to the top of the priority list yet..
Old Mar 3, 2010 | 10:02 AM
jefejrs's Avatar
jefejrs is on a distinguished road
Do the whole kit. One of the best mods I've done. Right up ther with my sargent seat.
Old Mar 3, 2010 | 03:16 PM
O.K. going to do the complete kit. From the Haynes manual the clutch holder looks easy to make, is there any thing else I should consider before starting.
inderocker
Feb 19, 2010 09:23 AM
FTMS
Aug 14, 2008 04:54 AM
ride57
Jan 29, 2008 08:27 AM
Skipperdabio
Jun 14, 2007 12:22 PM
MXC
Jun 18, 2006 05:16 PM
