rear cylinder won't fire
Old Jun 13, 2012 | 03:51 PM
hellonwheels's Avatar
hellonwheels is on a distinguished road
Exclamation rear cylinder won't fire
last week i did a compression test (165) both cylinders and then syncd my carbs. all is well....then i put it all back together and blam...no fire in the rear cylinder...so then i cleaned the carbs...replaced slow jet to a 48 replaced plugs...blew in the vacuum on the petcock and it flowed,,,bled float bowls lots of fuel....spray a little carb cleaner in the rear carb boom fires no carb cleaner no fire???
anyone???
Old Jun 13, 2012 | 04:19 PM
GTS's Avatar
GTS
Seasoned tech
If you crack the float bowl drain on the rear carb does fuel come out? If not then you've got a fuel supply problem. Did you make sure to turn the fuel petcock all the way on?
Old Jun 13, 2012 | 05:39 PM
yea man bled the bowl and the petcock is on all the way
Old Jun 13, 2012 | 06:02 PM
saige's Avatar
the boss
Check the plug for the coil,it might have come undone or loose.
It's in the loom under the seat.check all the wiring for the coil.
Old Jun 13, 2012 | 06:41 PM
wsharpman's Avatar
99 superhawk
+ 1 if it fires on spraying a mist in then its most likely a weak coil or wiring (due to the fact that a mist will fire on a weaker spark than liquid fuel).
Old Jun 13, 2012 | 10:19 PM
BeerHunter's Avatar
Slacker
Possibly a bad connection between the spark plug boot and wire.
Pull boot off plug, turn boot clockwise on the wire so that it bites better (the boot simply threads into the copper wire) , then reconnect to plug and try again.
The coil end of the plug wire could also cause the same problem.
Old Jun 14, 2012 | 05:42 AM
If you suspect a coil or ignition wiring issue, scrap the whole lot and do a COP swap..
Rid your self a possible source of trouble, some wiring and bulk, and get to "MOD" at the same time WIN / WIN
Old Jun 14, 2012 | 11:57 AM
Spilly talker's Avatar
Spilly talker is on a distinguished road
Seems like the plug/coil is a known weak spot according to everyone on here. I had a similar issue and have ordered a new set it's only $200 and even for a ham fisted twit like me, isn't too big a job!
Old Jun 14, 2012 | 04:08 PM
GTS's Avatar
GTS
Seasoned tech
It's possible that it could be a plug or coil but usually if it will fire when you spray some sort of starting fluid in the carbs but won't otherwies that's telling you it's not getting any fuel. I'd make sure the carb is getting a full constant supply of fuel and that all the jets are installed properly and none have come loose/fallen out or become plugged. Also make sure the float and float valve are operating properly.
Old Jun 14, 2012 | 06:50 PM
tell me more about that swap...
thanks
Old Jun 15, 2012 | 04:05 AM
RWhisen's Avatar
Former Superchicken Owner
thanks
Search for coil on cap mod.
https://www.superhawkforum.com/forum...cap-mod-23004/
Old Jun 15, 2012 | 05:31 AM
thanks
Well you could just click on the link in my signature titled "Coil on CAP MOD"
Old Jun 15, 2012 | 06:10 AM
BeerHunter's Avatar
Slacker
The coil on plug, or coil on cap, could be a good choice if you have confirmed that the problem is indeed electrical. If the problem lies elsewhere, then you are simply doing it because you have money to burn. Isolate the problem first before throwing money at it.
Try switching the coils that are already installed and see if the problem migrates to the front cylinder. If the rear still will not fire, then look to fueling or an air leak.
I can't tell you how many times I have reassembled things and then found a new problem, only to later find that I put some part together wrong, forgot to connect a hose, or made an incorrect adjustment. Retrace your steps and double check everything.
Old Jun 15, 2012 | 09:14 AM
Good points mostly, though it is a MOD in it self just to do in any case, loose some weight, clean up the are where the old coils are, and bring at least part of the bike in to something that is both modern, simple, proven and easy to do.
It's a WIN / WIN, even if it does not fix his issue.
CentralCoaster
Jan 13, 2010 07:30 AM
nova_scotian_996
Mar 26, 2007 10:33 PM
Arctic Fire
Jan 19, 2007 10:42 AM
L8RGYZ
Jan 16, 2007 01:55 PM
dustinwild
Jul 8, 2006 05:19 AM
