Lithium battery
Old Oct 30, 2019 | 07:38 PM
YellowBird's Avatar
YellowBird is on a distinguished road
Lithium battery
I need to replace my battery and want to use a lithium battery. Anyone know of what brand and model will fit?
Sorry if there is an existing thread on this but ifvthere is, I couldn't find.
If there is a reason not to go to lithium, please let me know and I'll stay with the norm.
Old Oct 30, 2019 | 09:14 PM
2.5i's Avatar
Permanent Student
2.5i is on a distinguished road
I’ve been using a Battery Tender (brand) BTL12A270CW Lithium battery, fits well in stock box, weighs 2.2lbs and has built-in BMS.
Old Oct 30, 2019 | 09:46 PM
You can definitely go with Lithium battery, but I would highly recommend to upgrade the R&R (regulator/rectifier) before you do it, Lithium batteries have a tendency to like a bit higher voltage charging than the OEM R&R, not to mention, it is a general recommendation on VTR's anyway, the OEM are pretty crappy to begin with and can potentially cause a very expensive repairs when they fail with 50% chance of frying all your electronics.
I have been using the same Lithium battery for the past 6 years now and it still strong with much better cranking power and 10 times lighter, I will never go back to regular battery.
There's allot more good options nowadays, you can look up Shorai, WPS, Featherweight, Antigravity and more.
But, definitely upgrade the R&R if you have't done it yet, there is plenty of great info on doing that here.
Old Oct 31, 2019 | 05:47 AM
I use the Shorai LFX18A1-BS12, same battery going on 3 years now. Just needs to make sure you have the charging system to support it. If you are not getting 13.8 or higher at the battery id not use a lithium
Old Nov 3, 2019 | 07:11 AM
YellowBird's Avatar
Thanks everyone.
I replaced the rectifier a couple of years ago so I should be good to go. Thanks for the brand and model number. When I do a search for batteries for Super hawk, no one seems to includdd lithium batteries. Thanks again.
Old Nov 4, 2019 | 05:15 PM
CaryDG's Avatar
I've been running the same as 2.5i in concert with Eric's Plug-n-Play R/R set up. Light weight and reliable. With the built in BMS you don't have to worry about killing your expensive battery by letting discharge to much.
Old Nov 10, 2019 | 08:16 PM
Pray tell which battery?
Old Nov 10, 2019 | 09:54 PM
I'm still running the lithium battery from Jamie Doherty that he used to offer on his website.
It's based on the A123 cells.
I just looked up when I got it, this is actually the 7th year I have it with very little maintenance.
Old Feb 17, 2020 | 03:18 PM
ACE VenTRa's Avatar
I run a bikemaster now---kicks ***.
20_rc51_00
Aug 29, 2014 09:34 PM
scottiemann
Mar 28, 2014 02:43 PM
smokinjoe73
Nov 8, 2010 05:17 AM
Christian_man30
Jun 3, 2010 07:55 PM
VTRFISH
Jun 19, 2009 09:40 PM
