First gen speedo connector
Old Mar 3, 2020 | 11:06 AM
rktdoc's Avatar
rktdoc is on a distinguished road
Looking for a source for the first gen speedo connector plug, want keep oem wiring intact.
Replacing my factory gauge set with a Koso unit.
Yes I've used search bar, actually found a mention of connectors source before. I checked motocorsa website but didn't see it.
Now I cannot find it back save my a double s.
Anyone else no where to find them?
Thanks in advance.
Old Mar 4, 2020 | 10:59 AM
Thanks in advance.
Your asking for the speedo side connector yes? Not the harness side correct
From Cycle Terminal http://www.cycleterminal.com/110-connectors.html
From Corsa https://www.corsa-technic.com/item.p...ategory_id=131
and
https://www.corsa-technic.com/item.p...ategory_id=129
double check the key ways and lock position compared to what you have but those should match.
Old Mar 4, 2020 | 07:32 PM
rktdoc's Avatar
Yes the speedo side . Many thanks the first link you posted, the one at the top page is actually it.
I was looking for parts for Aprilia at same time I posted sorta crossed names up. (Moto Corsa, Corsa Technic) scatter brains me I can't find what I'm searching for!
Appreciate this help, for some reason I Google til I was blue in face but just couldn't find these.
Old Mar 5, 2020 | 05:14 AM
Yes the speedo side . Many thanks the first link you posted, the one at the top page is actually it..
Your welcome,
You said " the one at the top page "
The early version analog speedo has two plugs, a 9 pin and a 6 pin, so not "one" , does your bike not have 2 plugs?
Old Mar 12, 2020 | 01:26 PM
rktdoc's Avatar
Your welcome,
Yes it has two plugs I had found the other one 6pin from a harness repair I had done years ago on another Honda used same plug.
Ordered the connectors now waiting on them to arrive. Hopefully the Koso speedo works out well.
Bergray
Jun 11, 2012 12:52 PM
smokinjoe73
Aug 24, 2011 11:46 AM
macworld
Jun 20, 2010 09:38 PM
steener
Mar 30, 2007 04:10 PM
barkmagnet
Nov 2, 2006 04:18 AM
