Gearing spreadsheet
Old Mar 1, 2007 | 12:07 AM
shayne's Avatar
Gearing spreadsheet
http://www.ozfirestorm.com.au/docs/sprocket_gearing.xls
This spreadsheet was originally for an FZ1, but has been updated with the VTR gear ratios. It has ben checked against a GPS and found to be accurate.
Simply type in your sprocket combo, and tyre size, and it will tell you what speeds you are doing at certain revs in each gear.
Cheers,
Shayne
Old Apr 20, 2007 | 11:00 AM
Cleveland's Avatar
Post Whore Junior
linky no worky for me....
Old Apr 20, 2007 | 05:18 PM
Hi Shayne,
I had posted the link to the spreadsheet on the OzFirestorm site in the Knowledge Base quite some time ago
Old Apr 21, 2007 | 04:02 AM
shayne's Avatar
I didn't know that. I actually put it up again because somebody, I forget who, asked me to. Pretty handy I found when trying to set my Speedohealer.
Old Apr 21, 2007 | 04:06 AM
shayne's Avatar
New link loaded. You should be right now.
Old Apr 21, 2007 | 07:30 AM
Hi again
I used the spreadsheet when programming my Speedohealer and it was a snap (15/43 meant reducing by 15.5% and done!)
Old Apr 24, 2007 | 03:44 AM
shayne's Avatar
Originally Posted by mikstr
Hi again
My work here is done.
Old Oct 11, 2007 | 04:53 PM
Slim's Avatar
Slim is on a distinguished road
Hey guys, I don't know if there's something wrong with my particular download or what, but when I try changing anything on the spreadsheet nothing happens. I can click on one of the gear ratios, but any input to the keyboard results in, well, nothing.
Any ideas?
Old Oct 11, 2007 | 05:05 PM
mini4m3's Avatar
mini4m3 is on a distinguished road
make sure you are changing the yellow boxes not the white?
Old Oct 11, 2007 | 05:09 PM
Slim's Avatar
Yup. The boxes with the sprockets are indeed yellow and are indeed the ones i'm trying to change ..... unsuccessfully.
Old Jan 16, 2008 | 05:38 PM
jim2000VTR's Avatar
jim2000VTR is on a distinguished road
gearing spreadsheet
He is correct... there is no formula tied to the sprocket cell. Anyone recall how it all worked? I'd be happy to update it, as I am pretty good at Excel, but no idea just how the formula worked.
jim
Old Jan 16, 2008 | 05:44 PM
Try this... my personal take on it...
File Type: zip
Old Jan 17, 2008 | 03:26 PM
jim2000VTR's Avatar
Thanks! I downloaded it a second time last night, and it worked fine, changing the columns as advertised. But yours is a lot easier, with the dual columns for comparison. Much appreciated!
jim
Old Jan 19, 2008 | 09:57 AM
All I did was edit the original one, and duplicated the formulae to be able to compare two different setups, other than just compare to stock...
Plus the the layout of the original one had me confused more than once...
Also added formuales making it easy to change the internal gearbox parameters, ie different bike...
Old Oct 23, 2008 | 09:31 AM
Sablotny's Avatar
ReNoob
Sablotny is on a distinguished road
I like Tweety's
Been looking around the forum at a couple different spreadsheets, this is the best. I think the bike is geared too tall, don't like the stock ratios for tight twisties. Some guys say 15/43 is too buzzy, but from the looks of it from this spreadsheet its really not a huge change. Loafing along at 3,500 RPM in 6th is 98 MPH.
Old Oct 23, 2008 | 12:16 PM
Killemall's Avatar
No need for spreadsheets. Gearing commander rulez!
http://www.gearingcommander.com/
AC COBRA
Jun 29, 2007 08:19 PM
wyldryce
May 16, 2007 07:59 PM
Otto Man
Mar 27, 2007 09:49 AM
Otto Man
Jan 17, 2007 06:47 PM
mikstr
Jun 9, 2006 05:36 AM
