Carb sync using a mighty vac
Old Mar 19, 2005 | 04:47 PM
caffeineracer's Avatar
caffeineracer
Here's the hook-up, be sure to use the brake bleed bottle on the mighty vac to damp the vacuum pulses.
Clamp off one line at a time and compare average (middle of needle swing) then adjust to be equal.
http://makeashorterlink.com/?R4C251F0A
[web:6878a0652d]http://makeashorterlink.com/?R4C251F0A[/web:6878a0652d]
Old Mar 19, 2005 | 06:03 PM
superbling's Avatar
Re: Carb sync using a mighty vac
Great Idea! This will finally give me the reason to buy a new miti-vac. My current one is several years old and the guage is no longer readable from the cheap brake cleaner spray I've used on it so many times. Still works tho'.
Do you use anything special to clamp the lines with, out of the ordinary?
I'm re-posting your pics in case that link goes bad in the future.
Old Oct 14, 2005 | 03:33 PM
AbeFM's Avatar
AbeFM
Thanks! I like that best of all (though I might still make my other puck-tube idea anyways).
Question: Do you need the mighty vac for anything, or shouldn't any old vacuum guage do?
I'm sure I could use the guage out of any of my various turbo vehicles... :-) But the resivour-as-damper is great!
________
Washington Dispensaries
Old Jan 14, 2011 | 10:56 AM
nothing's Avatar
ride it out
does anybody have the pics from this post? I just got a mityvac and was going to do the syncing, sorry for the old thread bump but if I would have made a new thread everyone would just ask "did you search"
Old Jan 14, 2011 | 12:03 PM
Well you can do the sync that way, though it is a bit "ghetto"
You would be better off with just a vacuum gauge as the one on the mityvac is pretty low quality.
With that you would just need something to adapt the mityvac line to the size of the vacuum nipples on the bike.
Instead of using the bleed container as a way to stabilize the reading I use a pilot jet pushed into the line as a restriction to accomplish the same thing.
98VTRrider
Dec 20, 2011 12:33 PM
nothing
Mar 16, 2009 04:13 AM
scarface
Sep 5, 2008 05:23 PM
Dave Wicks
Jun 21, 2008 06:56 AM
reaper
Sep 22, 2007 10:15 AM
