Why didnt I think of that?
Old Oct 23, 2014 | 09:41 PM
So I spend a lot of time making stuff like this. Like draft collars for my helmets, neoprene shifter covers to save my boots, etc.
I have seen the neoprene fork covers but this is brilliant. Especially if you ride in rain. Looks awesome to protect that expensive shock. Plan to make one soon. Will make some fork gators too.
R G Black Rear Suspension Shocktube for Kawasaki ER 6 Ninja 650R Up to 2008 | eBay
Old Oct 23, 2014 | 10:11 PM
HRCA#1's Avatar
Hey Joe they're lot's of guys buying HRC socks for their brake and clutch reservoirs! I;m still trying to figure why I didn't buy Airtouch before Verizon got'em. Then maybe I could afford to indulge in my fantasies!
Old Oct 24, 2014 | 06:55 AM
thedeatons's Avatar
I spoke directly with ohlins about these years ago when i had ohlins triple rates on my race quad. Thry told me specifically that shock covers reduced shock cooling significantly during heavy use, and they did not recommend them. I sold my shock covers immediately after speaking with them.
James
Old Oct 24, 2014 | 08:39 PM
Pidge's Avatar
Do they combat global warming too? (opps sorry climate change)
Old Oct 24, 2014 | 10:42 PM
Yes, well I am sure the good folks at Ohlins meant well, but until they start replacing my destroyed shocks I will be protecting them. Kinda like apply, lather, rinse, repeat. (or asking a barber if you need a haircut)
I mean, how insanely hard are you working a shock that its over heating? Maybe in the whoops on supercross but no one on the planet is over heating their shock going from point a to point b on the street.
Besides, I believe Honda would recommend against putting a pipe or jetting, tire companies say dont plug tires. The list goes on.
Old Oct 24, 2014 | 11:30 PM
jerryh's Avatar
I've run covers on all my ATVs for years. Definitely helps keep crud off them
Old Oct 25, 2014 | 08:40 AM
Jerry, what covers did you run?
Old Oct 26, 2014 | 04:41 AM
CrankenFine's Avatar
The shock probably gets warmer from proximity to the rear header than from work. The gator might keep it cooler (& combat climate change).
The gator on my mountain bike shock was made by Lizard Skins doubt they offer anything moto.
Old Oct 26, 2014 | 05:14 PM
jerryh's Avatar
Outerwear Joe. Velcro seam, they stay on and do the job. You could buy a set of three for a quad. They come in red by the way
Old Oct 26, 2014 | 05:15 PM
jerryh's Avatar
Yeah my mtn bike had a thicker neoprene cover on it when I bought it. The Outer wares are definitely thinner but hold up well
Old Oct 26, 2014 | 05:35 PM
SIRR1's Avatar
Deals Gap is a Hoot!
SIRR1 is on a distinguished road
Shocking just shocking!
Think about how many times per minute the shock rod moves up and down on an average days ride.
Add in the days temp plus the heat radiating from the motor and header then put a blanket on the shock so no outside air can move across the unit to cool the nitrogen and shock oil and there is a possibility the oil could foam and cause the shock to fail.
I have seen spring covers to protect the shock rod from damage but not the shock body it's self, if the folks at Ohlin's says not to do it I would go with their recommendation...
It could make for a long rough ride home if the shock seizes fully compressed.
JMO / SIRR1
Circuit_Burner
Oct 14, 2013 06:44 PM
j shizzy wizzy
Aug 10, 2013 04:00 PM
dshakes
Nov 20, 2009 06:32 PM
neilb
Sep 10, 2007 04:49 PM
caffeine-racer
Mar 9, 2007 04:23 AM
