What do you clean your engine with?
Old Mar 14, 2009 | 03:37 PM
oahu hawk's Avatar
geezer
Pulled the fairing for the first time the other day and was astounded by the 10+ years of road gunk build up on the front of the engine.
What do you guys use for tough jobs like this? I was thinking about one of those orange based automotive degreasers and a power washer.
Old Mar 14, 2009 | 03:39 PM
haknslash's Avatar
Mines never been super dirty to begin with. If yours is bad enough to where you need something stronger than water like degreaser or something...be sure to dilute it a bit. The magnesium and aluminum pieces are not hard to spot or etch with abbrasive cleaners
Old Mar 14, 2009 | 03:45 PM
j shizzy wizzy's Avatar
mildly retarded
simple green! or a bio degradable citrus based degreaser.
Old Mar 14, 2009 | 03:47 PM
mildly retarded
a cheap paintbrush works great to scrub off the gunk w/o scratching everything up.
Old Mar 14, 2009 | 05:11 PM
with a little diesel fuel this works great. if you got that much **** built up maybe while you're in there you should look for an oil leak/blown seal/gasket.
Be careful with the pressure washers. Really careful. When you rent one you don't know what you're getting. The one that we use to steamclean the greenhouses in the off-season tanks 180f water at 140 psi. It will literally peel the paint off your pickup. All it needs is a stone chip and off it comes.
Old Mar 14, 2009 | 05:24 PM
dakmatik's Avatar
dakmatik is on a distinguished road
+1 on the simple green. It works about the best out of anything and smells nice too.
Old Mar 14, 2009 | 05:34 PM
Simple green Power Sports washer.. They actually make it, and it was on sale for super cheap at Cyclegear.
Old Mar 14, 2009 | 06:00 PM
SlowHAWK's Avatar
Simple green as well... although WD-40 is pretty damn good at dissolving heavy areas of gunk as well.
J.
Old Mar 14, 2009 | 06:44 PM
aka Yamadog's Avatar
simple green! or a bio degradable citrus based degreaser.a cheap paintbrush works great to scrub off the gunk w/o scratching everything up.
Simple Green....Brush with paint brush...Rinse...Repeat.
Old Mar 14, 2009 | 07:03 PM
oahu hawk's Avatar
geezer
Simple Green and a cut down paint brush it is!...
Old Mar 14, 2009 | 08:38 PM
Purple Power, http://www.clean-rite.com/index.html I buy it at Napa buy the bucket. That and a pressure washer... works great every time. Be sure to s hose it off quick as it will stain oxidized parts.
Old Mar 14, 2009 | 09:31 PM
tosh23's Avatar
tosh23 is on a distinguished road
I do it to all my mates bikes when they get a new to them bike..
Fairy power spray , a tooth brush , and a house steam cleaner used for cleaning furniture and curtains. Ive used everything on the market and nothing touches Fairy power spray for deep grease and chain lube.
I dont know if you can get it in the USA tho'.
Old Mar 14, 2009 | 10:49 PM
Simple Green kills ants instantly as well.
Seriously!
Old Mar 14, 2009 | 10:53 PM
I've never heard of Fairy power spray, but then you Brits smoke ****. Whole different meaning here in the Colonies.
Old Mar 14, 2009 | 11:01 PM
oahu hawk's Avatar
geezer
Old Mar 15, 2009 | 09:02 AM
Simple Green is great. Wesley's Bleach White white wall/lettered tire cleaner is even better. And an old tooth brush works wonders. A pressure washer isn't necessary. Just scrub rinse and repeat a few times.
Old Mar 15, 2009 | 09:04 AM
chickenstrip's Avatar
chickenstrip
+1 on the toothbrush for tight spots
Old Mar 15, 2009 | 09:43 AM
RK1's Avatar
RK1
Cheapest way to go, works perfect. #2 diesel and a small paint brush with the bristles chopped back to about one inch length. Brush it on, hose it off, you're done.
Old Mar 15, 2009 | 10:10 AM
PUSHrod's Avatar
Simple Green, much diluted, and a parts washer brush and a bore brush. The parts washer brush gets into all of the little spaces and is great around the brake calipers. But only as Bike Week approaches. Once a year, whether it needs it or not.
justinity
Jan 24, 2011 08:24 PM
firehawk
Oct 8, 2009 07:16 PM
spdrcr
Sep 27, 2009 03:06 PM
chickenstrip
Jun 21, 2009 09:32 AM
