Water pump?
Old Mar 25, 2016 | 05:12 PM
SteelFire333's Avatar
SteelFire333 is on a distinguished road
Water pump?
Anyone have any clue as to what this might be? It's on the right side of the bike, just behind the upper cowling.
On hot days after a long ride I seem to have a very small amount of oil/gas leak. It doesn't active leak, but when I come back later there's a small dried up puddle underneath the bike.
Wondering if the relief valve I have pictured has anything to do with it.
Thank you all in advance.
Old Mar 25, 2016 | 07:40 PM
That is actually a weep hole for the coolant system. If memory serves me right, it means the seal around the impeller is leaking. You need to take the engine cover off and replace the impeller and seal. Since you are doing that, you will need to drain the coolant, so depending on your mileage, you will need to replace the coolant. Also, you will need a new right side engine cover gasket, which I found you can get off eBay at a decent price and they work great. If you plan on tackling this job yourself, check Patzilla.com for the parts you need. I have found that they usually have the best price.
Old Mar 25, 2016 | 07:52 PM
Awesome. Thank you so much. That actually makes sense, because my coolant in the resivoir was damn near empty...... And that could explain why. Thanks again
Old Mar 25, 2016 | 07:57 PM
THIS ^^^
time for a new seal, and possible impeller.
Pay strict attention to setting the impeller depth when you reinstall and be very gentle and careful when installing the new seal.... Its a tight fit, thin steel casing and easily damaged.
Check the impeller shaft for corrosion / wear.. if it is, replace.
Old Mar 25, 2016 | 08:01 PM
Thanks! I'm not as savvy as I'd like to be mechanically, so I'm definitely going to take my time. This'll give me something to do this weekend. Thanks again!
Old Mar 25, 2016 | 08:13 PM
If you haven't dowloaded it already, here is the link to the Superhawk's manual in pdf form.
superhawk996.net
Follow the instructions and you'll be fine. If you get stuck on something, just post your question and someone will chime in and help.
motojoe
Feb 6, 2008 09:03 AM
cozart02
Dec 25, 2006 09:23 AM
shayne
Apr 18, 2006 03:30 PM
inderocker
Feb 12, 2006 05:12 PM
jusv
Jan 22, 2006 07:57 PM
