Trouble using Vacuum Bypass Caps for PAIR-ectomy
I used a rubber vacuum cap from Autozone when I did my PAIR-ectomy. It didn't hold up very well. The cap in the attached pic was on the airbox nipple where the PAIR valve hose was attached. You might want to check yours if you used a similar rubber vacuum cap in that location.
Did my pairectomy when I got my bike when I first joined this forum and instead of using the vac cap as a cap, I found one that fit inside the airbox nipple, thereby using it as a plug instead of a cap and it is still just fine. Just an idea...
ohiophotog
Mar 26, 2015 04:50 PM
Psychobabble
Apr 21, 2014 11:02 AM
98VTRrider
Dec 20, 2011 12:33 PM
